Edge CTS trouble - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Longbob, this thread has received 11 replies and been viewed 3297 times.
post #1 of 12 (permalink) Old 08-10-2010, 02:54 PM Thread Starter
Edge CTS trouble
I searched the forums and didn't find the answers to these problems that I am having. Sorry if I come off as a newbie. I am new to the Fords, but not new to bombing diesels and monitoring them.
Here are the things I am dealing with and wanted to know if there are any good solutions. I have a 2004 6.0 F350 Crew Cab long bed. The Edge CTS mounts with a suction cup on the windshield. The problem is that Texas gets really hot and the Edge will blank out if it gets over 170 degrees or something. I cannot find a built in pillar mount that will help keep the sun off the unit. Does anyone make one for these trucks? I would like to hide the wires, also.
I am disappointed that it doesn't read the Engine Oil Temperature. This truck is completely stock except for a MBRP exhaust and a larger Titan tank. No tuners at all. The Edge CTS is the first thing I have hooked to it and it is just a monitor. I did add the EGT probe pre-turbo.
The tech person at Edge said that he didn't think the 2004 Ford OBD II read the engine oil temp, but I thought it did. I could be wrong. He said that it does read the Transmission Oil Temperature, but there is not a PID for the transmission. Is this a software update that I need to download from Edge?
Any help is greatly appreciated.
2000 2500 QC 4X4 Shrtbd Auto 3.54 gears White Laramie, Autometer Boost, EGT, and Trans gauges, AFE Stage 2, MBRP 4", F-1 1.6 injectors, Quick Diesel 64 Turbo, Smarty, TST Power Max 3, Goerend Full Billet, ATS Billet Flex Plate, Mag HyTech trans cover, PSC Quick Ratio, 2003 trackbar, DSS.
Longbob is offline
post #2 of 12 (permalink) Old 08-18-2010, 04:20 PM
DoneDunIt's Avatar
Adam at First Coast Diesel is a sponsor on this forum. I don't want to put up a link to another forum but he has the answer to your problems. I would contact him. I have a Edge CTS Evolution and have not had the problems with the EOT.
abrannan19 on this board
http://www.firstcoastdieselperformance.com/
(904) 813-5067
2003 CC SB 4X4 6.0 26,250 miles July 1, 2010
DoneDunIt is offline
post #3 of 12 (permalink) Old 08-18-2010, 04:38 PM
abrannan19's Avatar
you need to call edge right away, some of the first units are having this problem with the screens not working at high temps, they will replace this unit for you.
There is an update available (or will be) shortly to address the EOT and ECT and TFT on the 03-04 trucks, this problem has been fixed on the beta firmware.
abrannan19 is offline
post #4 of 12 (permalink) Old 08-19-2010, 02:27 AM
update the cts with the insight software. mine has all temps, including oil temp
2006 F250 CCSB
Thanks to Innovative and FCDP
SamW is offline
post #5 of 12 (permalink) Old 08-19-2010, 01:03 PM
abrannan19's Avatar
sam your truck is an 05. This is a problem with the 03/04 trucks only.
post #6 of 12 (permalink) Old 08-21-2010, 02:20 PM Thread Starter
I have called Edge tech support and pressed them a little for the update. They were wonderful and this is a completely different box! There are several useful PIDs now. It is so much better than the original set up, I am surprised that they would release it in what I considered a crippled product.
I need to call them back about the overheating issue. Mine will go out every time if I leave it attached to the window mount in our Texas heat. I called them about it the first time and the tech person told me it was a safety feature that shut it off at 170 degrees. His words. I also asked him about the PIDs at that time. He didn't know what I was talking about.
My first contact with the Edge tech support left a lot to be desired. Thank you for the responses!
Longbob is offline
post #7 of 12 (permalink) Old 08-23-2010, 07:05 PM
mattsn's Avatar
I have an '04 and my insight does not show oil temp
mattsn is offline
post #8 of 12 (permalink) Old 08-24-2010, 02:01 PM
abrannan19's Avatar
new insight or old insight? If its the old one, it does, there are not any issues with the older one.
post #9 of 12 (permalink) Old 08-24-2010, 09:37 PM
mattsn's Avatar
I just bought it about a month ago so I'm going to say it's the new one. Is there a fix for this?
mattsn is offline
post #10 of 12 (permalink) Old 08-25-2010, 02:24 AM
abrannan19's Avatar
which of these does it look like?
if its either of the last 2, call Edge and they will set you up with a beta version of a new firmware that will address the issues.
Tags
edge cts, oil temp, pillar mount
how much trouble imported_newtodiesel 2003-2007 6.0L Power Stroke 5 02-06-2008 12:47 AM
edge comp or edge juice w/attidue fitz1985 5.9L Cummins (1998.5-2002) 13 10-03-2007 02:43 AM
Trouble with edge HOT code bad_cummins 5.9L Cummins (1998.5-2002) 4 05-22-2007 04:56 PM
Edge Drag Comp vs. Edge Juice/Attitude lbdodge24v 5.9L Cummins (1998.5-2002) 12 03-08-2007 09:31 PM
edge juice and edge comp??? masonjo 24 Valve Performance 19 01-24-2007 12:51 AM
