SCT lock unlock question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BAF250, this thread has received 4 replies and been viewed 6008 times.
post #1 of 5 (permalink) Old 09-16-2010, 09:06 PM Thread Starter
Can someone tell me about this.
I see people stating their SCT has
x# of unlock left. Does that mean if
I start with 3 unlock and I load a custom
tune in my truck, then return to stock
and retune with same tune as before I then
have 2 unlocks remaining.
If so, how do some flip so many different peoples
custom tunes.
Thanks for the information.
05 F250 CC / 4x4 / 6.0 / CC / 20"x 8.5" / Toyo / 4" Pro FLo / AM GS Pyro / Bilstein shocks
SOLD F250 SD / PSD / SWB / CC / 4x4 / Silver / Med.Flint / TT Mirrors / RH Bullnose / Dipricol gauges / 35" BFG A/Ts / Bilstein shocks / Spray Liner / Billet grille / Edge 2" Mini Spring Pack / clearance lights / MBRP / XM Radio / 24" wipers/ PC Xtream 8085
BAF250 is offline
post #2 of 5 (permalink) Old 09-16-2010, 09:48 PM
Banned
custom tunes.
The unlocks only pertain to using your SCT from one vehicle to another. You can swap tunes all you want and not effect your unlock number.
wastedwagesracing is offline
The Following User Says Thank You to wastedwagesracing For this addition to TDG:
BAF250 (09-16-2010)
post #3 of 5 (permalink) Old 09-17-2010, 06:33 PM
Sumo Blue
What he said. You can change tunes and vendors an unlimited amount of times as long as the truck's PCM strategy does not change. I used up all of my unlocks at one point because Ford had reflashed my PCM so many times.
__________________________________________________ ________________________________________
2005 Harley Davidson F-250 Superduty #3991, true blue
"Slightly" Modded
Snake is offline
post #4 of 5 (permalink) Old 11-06-2010, 04:38 AM
Dually Club Member #96
06F450's Avatar
the "Unlocks" are refurring to this seniero, I have my truck programed with the tuner, the tuner is now locked(handheld unit), while locked the tuner is UNABLE to program anyother truck. Now somthing happens to my truck and i cannot reinstall the stock tune to my truck and the tuner is stuck in "Locked" mode, Now i have to call sct and pay them for an unlock code... now there are 2 "Unlocks" remaining.... this happened to me already.
2006 F450
SCT X3 Tuner (with EGR Off), A.R.P. Studs, AiRaid Drop In Filter, AutoMeter Pyro, Zoodad Mod, CCV Reroute, Hollowed & Piped Kitty, 4" Kitty Back Blown Coal in Front Of Rear Wheel, F550 Brakes, Splicer Rear End W/ 4:30 Gears, High Idle Mod, 12'x8' Harbor Contractor Combo Bed, More To Come After Economy Picks up. 13k All Day... Everyday
WARRANTY WORK :
(2) Altenators, (2) Batteries, (6) Sensors, (1) Turbo, (1) Full Engine Harness, (1) E.G.R. Cooler, (3) E.G.R. Valves, (1) I.C.P. Sensor... Hopefully thats it??? UPDATE10,2010; All Dummy Plug Seals, 2 fuel injectors, ECM, Both Silicon Boost Hoses, Clean Turbo... im sure theres more to come
7-2011 E.G.R. Cooler, Oil Cooler, Gaskets, Clamp, Filters, Fluid, Other BS... $1000 Work Done In Garage.
11-2-2011 Head Gaskets, degas bottle with cap, ring for turbo, egr cooler, temp sending sensor, radiator, thermostat, ficm, glowplug module, fluids, filters, and other gaskets... Material, tax, labor at dealer... $5900
A.R.P. studs... $466
11-15-11; Egr valve, and crank position sensor
06F450 is offline
post #5 of 5 (permalink) Old 11-06-2010, 04:45 AM
06F450's Avatar
And one more thing... NEVER SEND YOUR TRUCK TO THE DEALER WITH THE TUNER IN IT!!! After you get your truck back from the dealer and the tuner doesnt work because, the tuner needs to be updated with sct (its free, just time consuming). Just went thru this this week. Ford can reflash your truck 50 times and sct will keep up with the hex number, and we DONT have to unlock the tuners, just update them. KEEP THE COAL ROLLIN'!!!!
2006 F450
WARRANTY WORK :
06F450 is offline
Anti Lock Brake Question NotMyFirstBBQ 1994-2003 7.3L Power Stroke 3 12-17-2009 12:48 AM
SCT-ID Agg Street, Torque Converter lock/unlock? ebusa 2003-2007 6.0 Tuner Forum 8 02-17-2009 07:20 AM
SCT Unlock Question Clevelandjim 2003-2007 6.0 Tuner Forum 2 07-05-2007 12:09 AM
How to unlock an SCT Farm_Edition 2003-2007 6.0 Tuner Forum 1 11-08-2006 10:49 PM
TC Lock Unlock problems#2 lukesdiesel 5.9L Cummins (1998.5-2002) 8 07-13-2006 03:13 PM
