Exhaust! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by frankbailey1984, this thread has received 12 replies and been viewed 2253 times.
post #1 of 13 (permalink) Old 10-25-2010, 09:04 PM Thread Starter
Exhaust!
I just recently purchased my first diesel and love it. The other day i put the SCT Extream Street Tune on it and wow what a completely new truck!! I was wondering what is the best exhaust to get now that ive done this. I am running basicly and open exhaust now (took the mid pipe out) so its just free flow, but i want to be able to see the smoke when i really hammer it as opposed to it blowing all over the underside of my truck!! Look forward to the response!! 2006 F350 PowerStroke!
frankbailey1984 is offline
post #2 of 13 (permalink) Old 10-25-2010, 09:11 PM
Dually Club #3
jdydiesel's Avatar
Any of the systems on the market will work. It's your preference. You want shiny, quiet, loud, functional, cheap? I have the Banks Monster exhaust and I love it. It keeps the cat (which I have removed). It is 409 SS so it will last as long as the truck. It is great sounding when I stomp on it, but I do not have the highway drone that so many other exhaust systems have. But the down side is that it is about $500 when on sale.
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
post #3 of 13 (permalink) Old 10-26-2010, 02:45 AM
i dont have a diesel yet but if i did i would get the magnaflow turbo back it looks like it works very well but just as jdydiesel said any system will work
RGarza06 is offline
post #4 of 13 (permalink) Old 10-26-2010, 04:21 AM
I run the MBRP 4" turbo back with the cat delete...ran it with the muffler delete for awhile but at highway speeds the drone was too much...put the muffler in and it is perfect...stomp on it and you can hear it but as long as you keep in under 85-90 the drone doesn't get too bad. Good luck.
EL
Eric.Larson is offline
post #5 of 13 (permalink) Old 10-26-2010, 04:49 AM
& amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; amp; quot ;Mis s me yet&a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;a mp;q uot; George Bush
WasGas's Avatar
EL
+1 MBRP I only hear a droan on the X when towing 12k
AND YOU THOUGHT CARTER SUCKED
WasGas is offline
post #6 of 13 (permalink) Old 10-26-2010, 08:17 AM
Trip's Avatar
+1 MBRP, If I upgrade mine from my custom job to a 4" with down pipe it will be a MBRP, My friend has a 06 with the 4" 409SS I do envy the look and sound of it
To add to it he did cut up the 4" pipe where it dumps out the side and made several cuts and tig welded it back together so it dumps out where non exestant spare would have been due to having 40" mt's and LS diffs made no sense to keep the spare.
WALNUT (anti-ACORN) member#23
Trip is offline
post #7 of 13 (permalink) Old 10-26-2010, 05:13 PM
Supporting Vendor
crzycowboy's Avatar
Send a message via Yahoo to crzycowboy
Like mentioned above, any exhaust system will do what you are looking for. The only difference in "most" systems are the mufflers, and the clamps. Almost every manufacturer has a muffler design for their systems...some are similar to others, but still their design. Clamps are another good thing to look at. If it's a saddle or Guillotine style clamp it will have a tendancy to pinch the tubing leaving it unusable again if you have to remove that part off your truck for some reason. The band clamps are much better in this aspect as it does not damage the pipe. The other thing is the material used. While most thing 409 will out last the truck, this is not true. 409 can and will corrode. If you want an exhaust system to last the life of the truck 304 is the only material that will do that. If you want something to last 6-8 years...then Aluminized will do that...or if you want the 409 will as well. Depending on where you live climate wise and weather condition wise should be a factor before you purchase your exhaust system.
powered by Grand Rock
Josh Stewart
Technical Specialist
440-639-2000 (local phone)
800-321-3674 (Toll Free)
440-639-2010 (Fax)
[email protected] (email)
Visit our Grand Rock /Powerflow Store here: Grand Rock Store /Powerflow Store
crzycowboy is offline
post #8 of 13 (permalink) Old 10-26-2010, 08:58 PM
Bigking's Avatar
I'm running MBRP duals 409SS. I love the sound and looks of mine. Will smoke the entire road when i get on it.
05' F-250, Harley Davidson #2993, True Blue
SCT X2 programmer (innovative tuned), MBRP 4in turbo back SS Cool Duals, Gutted Cat, S&B cold air intake, 2" front 1" rear lift, 325x60x20 Nitto Terra Grapplers, Stock Harley 20" rims, Line X, 20% tint all around, Alpine Linear Sub system, 4k Sylvania Silver Star lights, Zoo Dad mod, line of fire by Recon, ARP head studs, RCD EGR delete, new heads, new Turbo, dual bilstein steering stabilizers, bilstein 5100 shocks all 4 corners, truxedo bed cover, Amsoil. U.S.C.G
Bigking is offline
post #9 of 13 (permalink) Old 10-27-2010, 02:50 PM
douglash's Avatar
+1 on MBRP, I have 4" on my excursion. No drone, now to figure out how to get my powermax to be quiet.
2004 EB Excursion MODS: EGR work, Powermax turbo, IDP Tunes by Eric
douglash is offline
post #10 of 13 (permalink) Old 10-28-2010, 07:14 AM
rocweiller's Avatar
I also have the banks. An exhaust is probably an exhaust so. I originally had the muffler from banks and kept cat on but that sound was just a teaser so I deleted both.. Nothing better than straight piped.. Stacks coming one of these days.
2008 6.4L PSD mods someday.
SOLD:2003 6.0L PSD. Tinted windows, Kenwood Cd player, Banks 4 inch Monster 1/2 way back to MBRP 6 inch Miter cut dual stacks, Rhino lined bed and rockers,S&B airfilter, Sct tuned by various, DiProcol Tranny, EGT and boost gauges in pillar mount, Go Rhino steps on 33x12.50 Toyo M/t's with black 18x9 Ultra Mammoth rims.Dfuser coolant kit,Ford Blue fuel pressure spring, ARP studs, Black excursion grill with enlarged Black emblem, 2008 tailgate with black emblem and black super duty lettering and 2008 tail lights RCD egr delete..
rocweiller is offline
FS: Chrome exhaust tip for powerstroke exhaust systems maxxis_mudder Whats Been Sold 7 11-06-2009 05:21 PM
Dual exhaust or single exhaust imported_7.3FordPower 1994-2003 7.3L Power Stroke 5 11-30-2007 12:58 AM
07-7-7 6.4l - Exhaust Smoke From Front Of Vehicle - Exhaust Odor Inside Vehicle Squatch Ford Oasis requests 0 04-06-2007 01:25 AM
04-9-4 Engine - Exhaust - Turbo-induced Exhaust Moan/drone At 1600-1800 Rpm - 6.0l Bu Squatch Ford Oasis requests 0 03-23-2007 12:59 PM
Exhaust, or no exhaust... that is the question. MaverickUF 2003-2007 6.0L Power Stroke 33 09-11-2005 04:58 PM
