oil bypass filter and coolant filter where does everbody mount them - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ranger518, this thread has received 29 replies and been viewed 17471 times.
post #1 of 30 (permalink) Old 10-30-2010, 03:52 AM Thread Starter
ranger518's Avatar
Hi i was watting to know if anybody had some ideas and pic of where they mounted there oilbypass and coolant filter on ther 6.0's i would like to mount both of them under the hood if possable and if not where should i mount them. Anything will help Thanks
ranger518 is offline
post #2 of 30 (permalink) Old 10-30-2010, 04:17 AM
strokin6L's Avatar
chances are, is that you're not gonna be able to mount both under the hood without relocating something else. I got my coolant filter under the hood, but the amsoil filter for the by-pass is on the passanger side frame rail.
strokin6L is offline
post #3 of 30 (permalink) Old 10-30-2010, 07:22 AM
There is only a few places you can install it here is the other
http://www.amsoil.com/bypassfilters/2006_F350_Pugh.pdf
To me the down side you need longer hoses and they have to go buy the turbo and over the exhaust not for me, i like mine better shorter hoses and they lay on the frame rail.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge CTS Expandable Pyro,AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Coolant Filtration System Delo ELC
Pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #4 of 30 (permalink) Old 10-30-2010, 04:42 PM Thread Starter
ranger518's Avatar
ok does it matter how long the hoses are like would it be better to mount my coolant filter or oil filter down on my frame or will it matter i am kinda worred about putting it down there for when i go off road.
post #5 of 30 (permalink) Old 10-30-2010, 06:50 PM
The longer the hose the longer it take to filter, i talked to Amsoil and they say do not go over 10' each way. I showed you how to install it and it works great for off road but it's up to you.
2 stroker
3" dp-4" exhaust
Tymar Intake
post #6 of 30 (permalink) Old 11-01-2010, 10:04 PM
Dually Club #3
jdydiesel's Avatar
Here's how I mounted my coolant filter.
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
post #7 of 30 (permalink) Old 11-02-2010, 12:25 AM Thread Starter
ranger518's Avatar
wow that is a great set up are you no longer using it i see that you have it blocked off
post #8 of 30 (permalink) Old 11-02-2010, 06:19 PM
Dually Club #3
jdydiesel's Avatar
That was the initial install. I didn't have the tee for the coolant line yet so I had it blocked. I am using it and I really like the way it turned out.
Jason
post #9 of 30 (permalink) Old 11-07-2010, 12:50 AM
maladosteo35's Avatar
Images: 2
2 stroker
2stroker; i have my coolant filter mounted about where your pic shows the oil bypass filter mounted. This leaves that oil filter 5-6 inches below the frame rail where it is exposed to everything. I was going to remote one of filters, i decided it would cause less damage if i lost a coolant filter versus losing an oil filter. I have my coolant filter mounted so it is higher than the frame rail, giving it better protection.
I have seen one pic where both filters were mounted and a tilt on a bracket off of the alternator. Looked good, but looked mighty hard to change the filters....
2005 F-250 Lariat CC FX4 4WD, Atlas 40 FICM, 200 amp Alt, 5th Wheel hitch, 5 inch Turbo back Cat/ Muffler delete, IPR EGR Delete, IPR Up=pipe, '08 banjo bolt mod, Blue Spring mod, AMSOIL oil bypass filter, Dieselsite Coolant bypass filter, Zoodad mod, High idle mod, CCV mod, Rotella T6 5w-40, Recon Blacked out third brake light/ side mirror turn signals, 7in Screen Double Din AM/FM/CD/DVD/ iPod ctrl/ NTSC TV eBay special, Rear 56" 5 way light bar
maladosteo35 is offline
post #10 of 30 (permalink) Old 11-10-2010, 02:11 PM
I have coolant filter on the passenger side of the radiator - I use the Bob Riley/Dieselsite kit - and my Amsoil bypass filter on the driver side rail on the outside. I also have a pre-pump filter on the drivers side rail on the inside.
I've never had a problem with either of them while on trails or off-road.
Good luck.
Al
FTG-05 is offline
Venturi update with bypass coolant filter? JFIN 2008-2010 6.4L Power Stroke 5 01-17-2009 04:46 PM
Bypass coolant filter system POWER STROKE 99 Supporting Vendors Forum 3 02-20-2007 12:16 AM
Amsoil remoute mount dual bypass filter setup ontherks Whats Been Sold 0 12-07-2006 06:15 PM
Coolant Filter / Oil Bypass Location hhrecovery 2003-2007 6.0L Power Stroke 22 11-07-2006 03:57 AM
FS: Amsoil bypass filter mount for under hood install on 6.0 PSD imported_Arkapigdiesel Whats Been Sold 2 10-22-2006 07:49 PM
