XFT (Extreme Fuel Addative) - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Levi'sford, this thread has received 6 replies and been viewed 2752 times.
post #1 of 7 (permalink) Old 11-10-2010, 07:38 PM Thread Starter
Levi'sford's Avatar
A buddy of mine uses this stuff in is Dodge, Semi Trucks, and Farm Equipment and swears by it (in a good way). Anyone used this stuff in a 6L? Any info would be great. Here is a link to the website.
www.bfnr.goxft.com
Thanks, Levi
2015 F350 Platinum, Crew Cab, Long Bed, 3.55, FX4, B&W Turnover Ball, Firestone Riderites w/ compressor
Levi'sford is offline
post #2 of 7 (permalink) Old 11-11-2010, 05:23 PM
strokin6L's Avatar
never heard of it. I only use opti-lube XPD mixed with 2 cycle oil.
strokin6L is offline
The Following User Says Thank You to strokin6L For this addition to TDG:
Levi'sford (11-11-2010)
post #3 of 7 (permalink) Old 11-11-2010, 11:00 PM Thread Starter
Levi'sford's Avatar
After looking it up on the web, it looks like a good old fashiod pyramid scam. Not to key on any product associated with that.
post #4 of 7 (permalink) Old 11-16-2010, 02:59 AM
harry6.0's Avatar
Check out the price of the stuff.
http://bfnr.goxft.com/cgi-bin/in1.pl...=USA&language=
Harry
harry6.0 is offline
post #5 of 7 (permalink) Old 11-16-2010, 04:16 AM
strokin6L's Avatar
Harry
HOLY CHIT!!! 1/4oz of that stuff will treat 20 gal. of fuel. I paid $42.95 for a gallon of opti-lube XPD....that is used as 1/2oz-3/4oz per gallon of fuel. Where as the XFT stuff is $1300 a gallon. I think i'll stay with my opti-lube.
post #6 of 7 (permalink) Old 11-20-2010, 07:02 PM
I have been using RBP Additive since new. I have a 2005 PSD with 103,000 miles. Daily driver. No injector problems, Use 1oz per 30 gals so I add 1oz per fillup. I think the RBP is simular- I really don't know anything about the product you are using I have seen it in the mags. I will stick with the RBP
vailcomp is offline
post #7 of 7 (permalink) Old 11-21-2010, 12:34 AM
strokin6L's Avatar
I've used RBP before. But after seeing test results in Diesel Power mag a while back.....there was testin done on different additives and which ones showed less wear....the opti-lube XPD was ranked #1. That was enough to make me use it.
Addative kcpanages 6.7L Cummins (2007.5-2011) 7 11-17-2007 03:13 AM
08 on Extreme 4x4 6.4lkid 2008-2010 6.4L Power Stroke 60 02-01-2007 05:49 AM
LLY PPE Hot extreme IdahoRob Whats Been Sold 1 03-31-2006 03:43 PM
extreme 4x4 haz-mat19 The Parking Lot 1 01-14-2006 07:00 PM
Extreme and PI? Dalpilot 2003-2007 6.0L Power Stroke 1 08-16-2005 04:53 AM
