high idle? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by stroke32, this thread has received 4 replies and been viewed 1393 times.
post #1 of 5 (permalink) Old 11-20-2010, 10:34 PM Thread Starter
Semper Fi
stroke32's Avatar
high idle?
saw the high idle option on my sct.. I set my idle to 875rpm. will I be ok with this choice? cold morning starts are ruff and need the truck warm to get to high way speeds. its been good and I like the high idle but is it safe on my truck and turbo?
black 2006 lariat F350 SB CC Dually sunroof 12" Procomp lift dual shocks/resivoirs front and rear, fabtech dirtlogic dual resivoir steering stabilizers (all nitrogen). 4in exhaust TB 22" chrome alcoa 18 wheeler rims on toyo 37" open country. 08-10 tailgate recon blacked out lights all way around. Harley front end (lights bumper grill etc) back up sensors and camera custom blacked out badges. 4 JL 10's in shallow box behind seats 2 thousand watt amps w/ custom 6x9's. 8" kenwood indash 5% tint all way around. powder coated frame and custom diff covers. SCT tuned
2005 f250 CC SB
custom all red truck grille and handles
black leather with carbon fiber face and door plates
IPCW taillights and lowered
stroke32 is offline
post #2 of 5 (permalink) Old 11-21-2010, 04:49 AM
harry6.0's Avatar
As long as its not making your transm jerk when shifting from park to drive or reverse, then it should be fine. I have a high idle switch hooked up on mine, but it only works in park/nuetral. If you forget to turn it off(like my wife does) and put it in gear, then it automatically returns to normal idle as soon as you depress the brake pedal, until you shift back into park, then it goes back up. The high idle mod is pre-wired into the upfitter wires on all 6.0's as far as I know. You just have to tap into the correct two wires under the drivers side underdash area and run them to a toggle switch. It makes my truck idle at about 1150-1200 rpm, which is good on cold mornings or anytime extended idling is needed, like while waiting for a 2mile long train in 10 degree weather, and you want that heater to stay nice and toasty. If your cold starts are rough or no power until warmed up, may want to try some 5w40 or 10w30 motor oil, or maybe you already do, I don't know. The thinner motor oil works better in colder weather for the 6.0
Harry
harry6.0 is offline
stroke32 (11-21-2010)
post #3 of 5 (permalink) Old 11-21-2010, 04:47 PM Thread Starter
Semper Fi
stroke32's Avatar
Harry
thanks for the response, 1200rpm is high for me lol. This is set at 875 consistent idle
2005 f250 CC SB
stroke32 is offline
post #4 of 5 (permalink) Old 11-23-2010, 02:43 PM
nitrogen's Avatar
the high idle mod harry refers to can be done in 15 minutes to any 6.0 with an auto trans.cost being a 6 in jumper wire. i frequently start the truck with it on. no harm is done then engine has to have oil pressure before it will even fire even then it usually goes 5-10 seconds before it spools up. FWIW i operate a 600 hp cat minimum idle is 1400 rpm, no prelube no fancy crap. cat built it an cat warranties it, no problems remotely related to high start up idle
Canadian Club #31
nitrogen is offline
The Following User Says Thank You to nitrogen For this addition to TDG:
stroke32 (11-23-2010)
post #5 of 5 (permalink) Old 11-24-2010, 12:47 AM
When I ordered my truck I also got the AIC. It only comes on when the trans is in Park or Neutral and the praking brake is set. Truck idles up to 1250 RPM. Keith
U. S. Navy Seabee Veteran.
We build, we fight , we drink more beer.
When you are up to your butt in alligators it is heard to remember the reason you are here is to drain the darn swamp.
ktpauley is offline
Skweeker Mod (High Idle or Aux. Idle) CBSuperduty Ford - Modification instructions, Product installs and Tech Articles 23 12-31-2009 04:22 AM
High Idle & High Idle Kicker... Mopar1973Man 5.9L Cummins (1998.5-2002) 4 12-25-2008 02:36 PM
High Idle Mod On Lmm? FX4DUDE Duramax 07.5-2010 (LMM) 2 11-04-2007 12:15 AM
High Idle & 3 Cylinder Idle Mopar1973Man 5.9L Cummins (1998.5-2002) 11 11-02-2007 02:44 AM
high idle Dieselpower01 5.9L Cummins (1998.5-2002) 10 05-09-2007 09:56 PM
