2006 -6.0- DIES - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MYWEIGH, this thread has received 9 replies and been viewed 2380 times.
post #1 of 10 (permalink) Old 12-18-2010, 02:25 AM Thread Starter
MYWEIGH's Avatar
2006 -6.0- DIES
MY SON'S 06 60 DIES WHEN IT WANTS TO. THAN THESE ERROR CODES OF V0306,V0105, PO500, P0500, P0237. ANY OF THESE THE CAUSE
MYWEIGH is offline
post #2 of 10 (permalink) Old 12-19-2010, 12:07 AM
SmokeCloud's Avatar
sounds like your FICM took a dump. does it idle really rough! like if it was missing?
Real Trucks Burn Diesel!
SmokeCloud is offline
The Following User Says Thank You to SmokeCloud For this addition to TDG:
MYWEIGH (12-19-2010)
post #3 of 10 (permalink) Old 12-19-2010, 12:14 AM Thread Starter
MYWEIGH's Avatar
HE SAYS ONLY WHEN IT'S COLD - WHAT IS THE [B][I][U]FICM ? I'M SURE IT'S A MODULE BUT THAT'S ALL I CAN FIGURE OUT.
THANKS FOR YOUR TIME.
'08 F350 6" PRO COMP, BANKS INTAKE, SUPERCHIPS - BUT LOOKING AT DELETE KITS AND PROGRAMMERS
MYWEIGH is offline
post #4 of 10 (permalink) Old 12-19-2010, 12:22 AM
SmokeCloud's Avatar
Fuel Injector Control Module. Have him check the voltage on it, I believe it should be between 12-13 volts.
post #5 of 10 (permalink) Old 12-19-2010, 12:25 AM Thread Starter
MYWEIGH's Avatar
THANKS AGAIN [/B]- WE'LL CHECK IN THE MORNING.
ARE THE TEST POINTS SELFEXPLANATORY OR DO IN NEED TO LOOK IT UP SOMEWERE
MYWEIGH is offline
post #6 of 10 (permalink) Old 12-19-2010, 12:28 AM
SmokeCloud's Avatar
Self Explanatory.
Another thing to check is the glow plugs. not everything throws a DTC, so you would need a scanner to see if it's throwing a code. but check your ficm then the glow plugs and glow plug solenoid.
post #7 of 10 (permalink) Old 12-19-2010, 03:04 AM Thread Starter
MYWEIGH's Avatar
WILL THE GLOW PLUGS MAKE A DIFFERENCE AFTER THE TRUCK HAS BEEN RUNNING FOR A WHILE?
THANKS AGAIN
MYWEIGH is offline
post #8 of 10 (permalink) Old 12-19-2010, 05:21 AM
SmokeCloud's Avatar
THANKS AGAIN
Yes and no. does the light go out before starting the truck, perhaps it's not warming up properly before starting it, which may be a bad solenoid. but for now check the ficm, glow plugs and the solenoid. report back.
post #9 of 10 (permalink) Old 12-19-2010, 12:47 PM
Incorrect info, 48-50 volts plus is correct, this high voltage is what actuates the HEUI injectors, part of the function of the FICM is to step up 12 volts to 50 volts.
There is plenty of info on testing the FICM on POWERSTROKE.org
http://www.powerstroke.org/forum/6-0...m-repairs.html
2004 F-250 6.0 Powerstroke, torqshift auto, supercab FX4 4X4, 8 foot box, Bright RED
DELTAJOHN is offline
The Following User Says Thank You to DELTAJOHN For this addition to TDG:
post #10 of 10 (permalink) Old 12-19-2010, 12:56 PM Thread Starter
MYWEIGH's Avatar
WE'LL GET TO TESTING THIS MORNING AS SOON AS JR. FALLS OUT OF BED
MYWEIGH is offline
04 f-250 dies nce05 2003-2007 6.0L Power Stroke 4 02-18-2010 10:11 PM
Starts and dies Super Limo 1994-2003 7.3L Power Stroke 6 11-17-2007 09:08 PM
rev up then motor almost dies gobigorgohome 2003-2007 6.0L Power Stroke 2 05-05-2007 04:54 AM
Cobalt SS dies TYREBOYZ_DMAXIN Road Kill, Bench Racing 5 04-09-2007 03:04 PM
runs then dies midnightcaper 1994-2003 7.3L Power Stroke 5 09-11-2006 02:36 AM
