SCT TUNER SWAP - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kanarman, this thread has received 2 replies and been viewed 823 times.
post #1 of 3 (permalink) Old 12-19-2010, 01:23 AM Thread Starter
SCT TUNER SWAP
A buddy of mine has a 04 6.0 with a sct tuner. It is for sale and i want to take it of his hands.Will it work on my 06 6.0?
kanarman is offline
post #2 of 3 (permalink) Old 12-19-2010, 03:15 PM
harry6.0's Avatar
Yes it will work on all yr model 6.0's, but it needs to be vin unlocked. They usually have 5 unlocks per tuner, which means it can't be used more than 5 times between different trucks before the tuner goes into the lock mode. If it still has available vin unlocks, then you will be ok, but highley recommend custom tuning for it for your truck and strategy. If the tuner already has custom tuning programmed for your buddies truck strategy, then its not going to work unless your strategies are the same, which is very unlikely. If the tuner has canned general programming, then it should work as is, but is far from a custom tune program.
http://www.sctflash.com/support/inde...cleid=24&nav=0
Harry
harry6.0 is offline
kanarman (12-19-2010)
post #3 of 3 (permalink) Old 12-19-2010, 05:30 PM Thread Starter
Thanks Harry I am going to ask him if it is unlocked or if he can unlock it?He said it was a older model sct?
Thanks again.
kanarman is offline
SCT 9625 OR tuner '08 0r '09 6.4l Delete tuner $450 shipped! 4613 Whats Been Sold 1 01-02-2010 01:08 AM
turning the SCT SF tuner into a custom tuner strokin6L 2003-2007 6.0 Tuner Forum 4 05-26-2009 04:05 PM
What to do 12V swap or 3rd Gen scoobysmak 5.9L Cummins (2003-2007.5) 3 04-15-2008 03:51 AM
Swap a 7.3 in a 05 2tonePSD 1994-2003 7.3L Power Stroke 13 03-10-2008 12:43 AM
6.5l swap NH2112 6.5L Diesel Engine 0 11-08-2005 02:07 AM
