EGR Delete Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dcboyz, this thread has received 12 replies and been viewed 2422 times.
post #1 of 13 (permalink) Old 12-28-2010, 05:10 PM Thread Starter
EGR Delete Question
I have an 06 and Im thinking of deleting the egr before it becomes a problem. Do I need to change the tuning after? I only have an air raid intake and a bully dog gt right now, Im not even sure if the bully dog is able to do that anywayz.
dcboyz is offline
post #2 of 13 (permalink) Old 12-28-2010, 05:14 PM
bushpilot's Avatar
you MAY get a CEL (check engine light) when the EGR is blocked off - some do, some
dont (as and example i dont, but lonnie does). Im told tuners can eliminate that CEL.
If i were you, id get rid of that air filter !
Don R.
Truck Audio,
bushpilot is offline
post #3 of 13 (permalink) Old 12-28-2010, 05:20 PM Thread Starter
it was on there when i got the truck, any particular reason why?
dcboyz is offline
post #4 of 13 (permalink) Old 12-28-2010, 05:28 PM
bushpilot's Avatar
it does nothing for increasing hp or improving mpg - if anything it shortens the life
of the turbo compressor vanes and allows foreign object damage (aka water/sand/dirt or
WORSE).
running a gauze filter requires significantly more maintenance (my bet is yours is dirty,
now, no different than most) and provides no hp or cost savings benefit.
https://thedieselgarage.com/forums/sh...d.php?t=104573
Don R.
Truck Audio,
The Following User Says Thank You to bushpilot For this addition to TDG:
dcboyz (12-28-2010)
post #5 of 13 (permalink) Old 12-28-2010, 05:44 PM Thread Starter
Ok well I can see where that might affect the performance... I dont know how long it was on there before I got the truck but Im definitly gonna look into replacing it. After reading some of these other posts about tuners Im not so sure about this bully dog anymore either...hardly anything in here about them at all.
dcboyz is offline
post #6 of 13 (permalink) Old 12-28-2010, 06:17 PM
bushpilot's Avatar
the factory/donaldson air filter is proven to be sufficient to at least 500hp, noting filters
better for your truck - any after market filter that claims to flow more air WILL also
flow more DIRT !
the ONLY line of defense immediately in front of & protecting your turbocharger
is the air filter !
you can find less expensive OE replacement filters at dieselfiltersonline.com - stay away from
the primeguard OIL filters.
the RACOR air, fuel & oil filters are fine and meet OE spec.
the NTZ (factory) trans by-pass filter is an excellent <cheaper alternative> too.
you may also fine the FRAM filters at walmart a good <cheaper> & locally available
alternative oil filter.
Don R.
Truck Audio,
post #7 of 13 (permalink) Old 12-28-2010, 08:25 PM
allstarsixo's Avatar
Yep! My light came on but like Don said you can get an SCT to turn it off and yes I second the air filter....
Lonnie
allstarsixo is offline
The Following User Says Thank You to allstarsixo For this addition to TDG:
bushpilot (12-28-2010)
post #8 of 13 (permalink) Old 12-29-2010, 01:32 AM
ranger518's Avatar
on a 06 you will get a check engin light just got done doing mine and i got it i think late 05-07 you will get one you can leave your egr sensor in the intake and it still thinks it is working and you will not get the check engine light i just took mine off and am going to get a SCT tuner with custom tunes.
I think it is great that Cummings service trucks are f-550 with 6.0 and 6.4. They must know somthing?
2006 F-250 lariat FX4
4" turbo back MBRP stainless steel exhaust cat delete
Airaide intake
Homemade coolant filter
Custom oil bypass filter
Quad pillar gauges EOT, ECT, Fuel pressure, and EGT
RCD EGR kit with new up pipe
Blue Ford fuel spring went form 45psi to 68psi part number 3C3Z-9T517-AG
Rancho Rs9000 shocks with my ride controll
Homemade 3" lift
315x70x17 BFG AT's
SCT With custom Innovative tunes
Mobil ELC Cat-1 Coolant
2004 Turbo
Zoodad mod
ranger518 is offline
post #9 of 13 (permalink) Old 12-30-2010, 01:51 PM
Not true! I still have my EGR in and plugged in. The Check Engine light will still come on!
Lonnie
bushpilot (12-30-2010)
post #10 of 13 (permalink) Old 12-30-2010, 02:07 PM
ranger518's Avatar
Lonnie
Not sure then it worked on my buddys truck had a cell for the EGR after delete install so be put the sensor. Back in an it went away did come back on but be said that he just neaeded to clean it and put it back in. Not sure that js just what I was told.
Airaide intake
Homemade 3" lift
315x70x17 BFG AT's
2004 Turbo
Zoodad mod
EGR Delete question gator_boy_77 2003-2007 6.0L Power Stroke 12 01-25-2010 12:39 PM
EGR Delete question 03lariatsd 2003-2007 6.0L Power Stroke 2 01-17-2010 05:53 AM
EGR Delete Question Powerstroke85 2003-2007 6.0L Power Stroke 9 11-01-2009 02:52 PM
Delete question nickdoni 2008-2010 6.4L Power Stroke 20 02-10-2009 05:36 PM
dpf delete and egr question imported_MEGAcab Duramax 07.5-2010 (LMM) 6 05-03-2008 01:10 AM
