Just bought a 2005 6.0 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TubingJon, this thread has received 10 replies and been viewed 2487 times.
post #1 of 11 (permalink) Old 05-09-2011, 02:48 AM Thread Starter
TubingJon's Avatar
Looking for a tuner, exhaust and intake. Who has the best product as far as quality and performance, cost is secondary.
Thanks, Jon.
TubingJon is offline
post #2 of 11 (permalink) Old 05-09-2011, 06:10 AM
MT KingRanch's Avatar
Good Luck, better talk to BulletProof Diesel before plugging in that tuner. Start reading threads on this forum before pouring the hp to it.goodluckdangerbeerdrink
'04.5 F-350 Super Duty King Ranch-BulletProof Diesel EGR Delete/ Remote Oil Cooler w/ thermostat regulated return,By-Pass filter, BPD Scan Gauge II, DieselSite Coolant Filter,4" FlowMaster Exhaust/5" Downpipe, AEM HD Intake,Boost/Fuel PSI/EGT Gauges, Lund Fiberglass Running Boards,Fender Flares and Visor,Front end leveling kit, Toyo Open Country 275-70R-18's, ArchOil 9100 & 6200.
Atlas40 Tuned FICM.
MT KingRanch is offline
post #3 of 11 (permalink) Old 05-10-2011, 06:33 PM
cut cat and muffler off
If you live in a state that doesnt do veh insp. then just go ahead and cut the cat and muffler off. you'll get a better sound and better gas mileage. it cost about 50 bucks if you have someone do it. or at least here
Huskerville is offline
post #4 of 11 (permalink) Old 05-11-2011, 02:21 PM
Thanks, Jon.
Dont waste your money on a intake, as the stocker is good to 500HP.
Exhaust, go with MBRP. There stuff is real nice, im a dealer for them and have had MBRP on both my diesels. LOVE IT. do a 4" Turbo back, you choose if you want a muffler or not, stainless or aluminized.
Tuner, Go SCT. Call innovative diesel for tunes, they will hook you up!
PowerChoker332 is offline
post #5 of 11 (permalink) Old 05-11-2011, 05:23 PM
1996 ford F-250 EX-Cab Shortbed 5-speed 7.3l psd
Dp tuner
165cc injectors
D66 turbo
3 gauge pillar
southbend clutch
coustom intake
3'' down pipe
8'' miter cut single stack
firestone destinations
1996 Stroker is offline
post #6 of 11 (permalink) Old 05-12-2011, 02:43 AM Thread Starter
TubingJon's Avatar
Shoot me a PM with a cost on SS in the 4" turbo back minus the muffler, I like to be able to hear them.
Thanks, I fly in to Louisville Saturday morning and drive it home to MI!
post #7 of 11 (permalink) Old 05-17-2011, 12:51 AM
SickStroke6.0's Avatar
I've got an SCT X3 and an X2 I'd sell you if you're interested.
Blake
2003 Ford F-250 6.0l Powerstroke CC SB Lariat FX4
Engine-ARP Studs, RCD EGR Delete, 4" MBRP Exhaust, SCT Tuned by Innovative
Exterior-2.5" Leveling Kit, 18" XD Badlands, 325/60/18 Nitto Terra Grapplers
Interior-Edge Insight w/EGT
WTB: 6.0L Injector Cores
SickStroke6.0 is offline
post #8 of 11 (permalink) Old 05-17-2011, 06:16 AM
Did you move up to a LiveWire?
06' F250 Mods:
Performance related:
-K&N E-0780 Air Box, ZooDad Mod
-Garrett Powermax Turbo, CFM+ Smallmouth Intake Manifold
-Blue Fuel Pressure Spring, Large fuel lines from pressure regulator to heads
-MBRP 4" Turbo back exhaust; cat installed
-SCT SF3 Tuner w/SRL custom tunes from Matt at GearheadAutomotivePerformance.com
Reliability Mods:
-Refurbished 50 volt FICM, Eliminated STC fitting, upgraded stand pipes and dummy plugs, Bulletproof Diesel EGR cooler, upgraded turbo oil supply and drain
-Oil change rotation; 5k-5W40/5k-15W40/5k-15W40
--Rotella T5 or Valvoline Blue Extreme 5W40, Rotella or NAPA 15W40, Archoil 9100 friction modifier (16 ounces to crank case; 10 ounces to each differential)
--2/3 Qt. tcw3 2 cycle oil per tank Power Service (5 oz. Stanadyne every tank)
-Cooling system flush with Restore and VC-9 @ 73,000 miles w/new thermostat
-Eliminated clunk while sitting at a light (75,000 miles); Lubed rear drive-shaft spline with Ford lubricant; Symptom returned at 100,000 miles...re-lubed at 112,000 miles....wow!! it's so smooth again.
Miscellaneous:
-1/2" shim on carrier bearing mount
-Batteries:
--Original Motorcraft lasted 4 1/2 years
--AutoZone Duralast Gold lasted less than 3 years
---(with 2/0 cables between + terminals)
--Still on 2nd set of Autozone Gold (replaced free)
-Alternator:
--DC Power 185 amp
Future Mods:
-Teflon sway bar bushings
-Moog Ball Joints (originals seem to be holding tight at 108,000 miles; it's just a daily driver, so this seems to make sense)
-Cooling system filter
-OEM HG/ARP studs
bustedknuckles is offline
post #9 of 11 (permalink) Old 05-19-2011, 06:40 AM
. No way man, the LiveWire sucks. This is my buddy's.
Blake
post #10 of 11 (permalink) Old 05-19-2011, 05:14 PM Thread Starter
TubingJon's Avatar
What are the differences and who's tunes? I have been out of the 6.0 loop for a while so I don't know all the ins and outs yet.
Just bought a 6.4L F-350 TLadd 2008-2010 6.4L Power Stroke 2 12-03-2010 11:44 PM
Bought 2005 Excursion allstarsixo General Ford Truck and Excursion 6 08-17-2010 02:56 AM
Just Bought a 02 7.3. aikimo 1994-2003 7.3L Power Stroke 8 09-09-2009 12:30 AM
bought 7.3 and have ????? big peter 1994-2003 7.3L Power Stroke 6 04-29-2009 01:39 PM
2005 Excursion PS vs. 2005 F-series PS deb0650 2003-2007 6.0L Power Stroke 3 04-07-2007 07:23 PM
