blew up transmission with river city diesel tunes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tmoriarty19, this thread has received 8 replies and been viewed 8461 times.
post #1 of 9 (permalink) Old 06-06-2011, 08:45 PM Thread Starter
Tyler
its an 06 f250 with 110k on it. its my brothers truck and i have done trans filters and a drain and refill every 25k and the fluid was never that dark, then he got an sct x3 with the rcd custom tunes and had a bunch of problems, my exact same truck with 140K and sct street tune will walk away from his with the rcd race tune. but anyways he said his trans temp maxxed out the one day so i pulled the plug and the fluid was black. i pulled the pan and about 2cm of metal shavings and the filter housing was filled to the top with shavings. i am a diesel tech at the local dealer so i cand get a factory rebuilt for 2500 with a 3 year unlimited mileage warranty. or should he spend the money and get the ats one that is 5300$ or are there any other cheaper better trans companies out there. i personally feel that it was river city diesels tune that ****ed it up but no way to tell and sct and rcd are both denying any type of assistance with it. sct says its the custom tunes and rcd says its the mileage. i know stuff happens but i have never seen one come apart like that
tmoriarty19 is offline
post #2 of 9 (permalink) Old 06-06-2011, 09:49 PM
Kip
In the passing lane
Kip's Avatar
I can't seriously be blaming the tuner for the tranny problems? When you add power the weaker parts are gonna break.
2005 2500HD DIRTYMAX 6in lift, dual exhaust, afe airbox. Tuner soon to come
2001 PSD shortbed crewcab, ATS tranny edge juice w/attitude, Superchips programmer, Gauges, exhaust, 4inch lift w/35s, (SOLD)
Originally Posted by sledneck57
Your sweating like a queer holding a hot dog.lol.
Kip is offline
post #3 of 9 (permalink) Old 06-07-2011, 01:57 AM
plainredtruck's Avatar
Images: 11
First off, you play, you pay.
Power adders + 110K + . . .
Get factory rebuild. Chances are he won't have the truck another 3 years anyway, will he?
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #4 of 9 (permalink) Old 06-07-2011, 09:20 PM
350FORD's Avatar
You play, you pay. still stock original trans. 171,xxx, the last 130,000 w/ a tune. Its all in how you use it. pointing fingers at a company is just not right. You should have known you were resposible for the truck the moment you plugged it in.........................
03' F350-DRW, SB
SCT TUNES BY DOUG, MBRP, INTAKE
174, 940 mi.11/16/11
bcbsupply.com
350FORD is offline
post #5 of 9 (permalink) Old 06-08-2011, 12:59 AM
SLAPS President
teamroper60's Avatar
Images: 9
Originally Posted by tmoriarty19 View Post
its an 06 f250 with 110k on it. its my brothers truck and i have done trans filters and a drain and refill every 25k and the fluid was never that dark, then he got an sct x3 with the rcd custom tunes and had a bunch of problems, my exact same truck with 140K and sct street tune will walk away from his with the rcd race tune. but anyways he said his trans temp maxxed out the one day so i pulled the plug and the fluid was black. i pulled the pan and about 2cm of metal shavings and the filter housing was filled to the top with shavings. ...............
I am not saying the tuning couldn't have caused a problem (I wasn't there, so I don't know) but what you just described as being in the pan and filter housing did not happen because of "one day". It sounds to me like that tranny has been abused over a much longer period of time than that and I seriously doubt the owner had no hand in that abuse...... He should have realized something was amiss long before it ended up with all that debris in the pan and filter housing.
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #6 of 9 (permalink) Old 06-13-2011, 03:48 AM
strokin6L's Avatar
just go with a factory rebuild. DO NOT go with ATS if you get an aftermarket trans....they suck and customer service sucks along with it. I personally haven't dealt with them or have their trans, but i and others haven't heard anything good with them reguarding ford transmissions.
strokin6L is offline
post #7 of 9 (permalink) Old 06-15-2011, 05:04 AM
Slow 6.0
sounds like all he needs is a factory trans.
2006 F350 XLT 4x4
SICKS-O is offline
post #8 of 9 (permalink) Old 06-15-2011, 02:10 PM
Kip
In the passing lane
Kip's Avatar
I had zero problems with my ATS. In fact I would rather have my tranny out of my stroker than the allison I have now.
Kip is offline
post #9 of 9 (permalink) Old 06-15-2011, 09:16 PM
Slacker
carlson158's Avatar
Interesting. I know they do well in the Chevy market, although they have treated several folks with 5R110's that I know personally pretty badly. I hadn't heard many good things concerning them with Fords and you are the first that I have heard of having a good experience with a 4R100.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit)
Engine Mods:
ARP studs
Fluidampr
CCV Reroute
4" MBRP Exhaust
S&B Cold Air Intake
Bypass Coolant Filter
BulletProof EGR Cooler
Garrett PowerMax Turbo
Dieselsite Intercooler Boots
SCT w/ Custom Tunes (DJ's, Innovative)
BulletProof Oil Cooler System w/ Bypass Filter
Gogo Diesel Direct Drive Solenoid
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
18" MotoMetal 950's wrapped in 33" ProComp Extreme AT's
carlson158 is offline
River City Diesel Tunes.. rocweiller 2003-2007 6.0 Tuner Forum 2 05-04-2010 05:49 PM
Hello River City Diesel!!! crazyrc 2003-2007 6.0L Power Stroke 16 12-02-2009 10:47 PM
River City Diesel Tunes 08burnincoal 2008-2010 6.4L Engine Tuner Forum 155 06-09-2009 01:55 AM
Big thanks to river city diesel Bcarriveau 2003-2007 6.0L Power Stroke 12 01-05-2009 07:54 AM
