Towing with a tune? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ALBOB, this thread has received 6 replies and been viewed 1909 times.
post #1 of 7 (permalink) Old 09-23-2011, 12:15 AM Thread Starter
Towing with a tune?
'07 F-250 6.0PS
SCT Excellerator II Power Tune
MBPR Exhaust
Volant Cold Air Intake
No other mods
Empty I get close to 20 MPG at highway speeds.
Pulling our old camper that would drop to 10 MPG
I recently purchased a 5th wheel that tips the scales at over 11K pounds and my mileage dropped like a rock. Would I be better served to flash back to the stock tune when towing and only use the Power program for empty trips?
Thanks
Rules? You mean there are rules for that?
ALBOB is offline
post #2 of 7 (permalink) Old 09-26-2011, 06:48 PM
Stuck in Commiefornia...
IdahoF350's Avatar
Looks like you're towing about the same weight I do. Put it back to stock, hit the Tow/Haul button and let the truck do the job. Doesn't look like you have head studs yet, even with them, I have a tow tune that is primarily for the exhaust brake and nets me another 1/2mpg towing. I get 9-1/2 to 11mpg tank to tank and average out just over 10mpg. 11k is a lot of weight and a 5th wheel adds a lot of frontal area. Pull the tailgate off when your towing for a small bump in mpg, and slow down. Over 60mph towing massacres your fuel mileage.
2000 Excursion XLT 4x4
IdahoF350 is offline
post #3 of 7 (permalink) Old 09-26-2011, 09:50 PM Thread Starter
Thanks Idaho, that's exactly the kind of info I was looking for. If I can get somewhere close to 10MPG again I'll be jumping for joy.
P.S. Keep a happy thought. I was trapped in Tehachapi for almost three years. Escape is possible.
ALBOB is offline
post #4 of 7 (permalink) Old 11-08-2011, 06:30 PM Thread Starter
Idaho, you are the MAN!!! Just got back from a relatively short trip but, it had a LOT of steep climbs. Averaged just a hair under 10MPG for the trip and couldn't be happier. I was VERY worried that my MPG with the new trailer was going to limit my travels next year. Now we're back in action thanks to you. Much abliged. handshake
ALBOB is offline
post #5 of 7 (permalink) Old 11-09-2011, 05:49 AM
I pull a 14k 5er solo i get 18.4 and pulling i get 8.5 to 9.5 with ECT 218* EOT 228* on a 6% grade about 6 miles long at 90* outside and 25lbs of boost and no tunes.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge CTS Expandable Pyro,AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Coolant Filtration System Delo ELC
Pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #6 of 7 (permalink) Old 11-15-2011, 11:31 PM
IdahoF350's Avatar
2 Stroker: I'd bet your total fontal area is about the same, maybe a little more than mine, and that combined with the additional 3000lbs is the difference in fuel economy. The angle of the front of the 5th wheel will make a small difference too, if you have a near vertical cap on the front of the trailer it can cost you 1/2 mpg vs. a sloped nose like what my Prowler was designed with.
post #7 of 7 (permalink) Old 11-16-2011, 01:18 AM
Yes i have a high front on mine about a 6-6.5' bedroom and the newer 5er do hit the wind alot better. I just installed a Roll-N-Lock bed cover took a 500mile solo trip over to Sunriver for a week and got 1/2+ more per-gallon then we went to the coast for a week and got a little better mpg pulling by pulling the cover up to the hitch but the good part is everything stays dry and covered.
2 stroker
3" dp-4" exhaust
Tymar Intake
Best H&S Tune for towing ? cglenn 2008-2010 6.4L Engine Tuner Forum 1 06-25-2011 05:45 AM
What tune are you Towing with? Truckmaniac 2008-2010 6.4L Engine Tuner Forum 5 04-18-2011 05:26 PM
towing with 275 tune Quantum 2008-2010 6.4L Engine Tuner Forum 13 07-07-2009 02:28 PM
towing 150 tune Quantum 2008-2010 6.4L Engine Tuner Forum 10 03-24-2009 05:19 AM
Who has the best towing tune ? 760 PSD 2003-2007 6.0 Tuner Forum 3 07-27-2007 03:24 AM
