Latest SCT SF3? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bustedknuckles, this thread has received 1 replies and been viewed 1015 times.
post #1 of 2 (permalink) Old 09-24-2011, 04:25 AM Thread Starter
Latest SCT SF3?
How do I tell whether I got the latest SF3 flash programmer?
I see on the SCT site a different label on the front. The programmer says SF3 right on the front of the tuner.
Is there a reason to be concerned? My tuner part number is 3015, but the front of the tuner is very generic looking. I just says SCT, More Power/Less Fuel, Pre-Loaded Flash Device.
Has anyone else bought the 3015 and received the latest front label?
06' F250 Mods:
Performance related:
-K&N E-0780 Air Box, ZooDad Mod
-Garrett Powermax Turbo, CFM+ Smallmouth Intake Manifold
-Blue Fuel Pressure Spring, Large fuel lines from pressure regulator to heads
-MBRP 4" Turbo back exhaust; cat installed
-SCT SF3 Tuner w/SRL custom tunes from Matt at GearheadAutomotivePerformance.com
Reliability Mods:
-Refurbished 50 volt FICM, Eliminated STC fitting, upgraded stand pipes and dummy plugs, Bulletproof Diesel EGR cooler, upgraded turbo oil supply and drain
-Oil change rotation; 5k-5W40/5k-15W40/5k-15W40
--Rotella T5 or Valvoline Blue Extreme 5W40, Rotella or NAPA 15W40, Archoil 9100 friction modifier (16 ounces to crank case; 10 ounces to each differential)
--2/3 Qt. tcw3 2 cycle oil per tank Power Service (5 oz. Stanadyne every tank)
-Cooling system flush with Restore and VC-9 @ 73,000 miles w/new thermostat
-Eliminated clunk while sitting at a light (75,000 miles); Lubed rear drive-shaft spline with Ford lubricant; Symptom returned at 100,000 miles...re-lubed at 112,000 miles....wow!! it's so smooth again.
Miscellaneous:
-1/2" shim on carrier bearing mount
-Batteries:
--Original Motorcraft lasted 4 1/2 years
--AutoZone Duralast Gold lasted less than 3 years
---(with 2/0 cables between + terminals)
--Still on 2nd set of Autozone Gold (replaced free)
-Alternator:
--DC Power 185 amp
Future Mods:
-Teflon sway bar bushings
-Moog Ball Joints (originals seem to be holding tight at 108,000 miles; it's just a daily driver, so this seems to make sense)
-Cooling system filter
-OEM HG/ARP studs
bustedknuckles is offline
post #2 of 2 (permalink) Old 09-24-2011, 09:38 PM
lilpooh's Avatar
I don't know why SCT changed labels, but if the part number says 3015, then it's a SF3.
For some reason SCT likes to do weird stuff, take the X-3's for example. The original X-3 is capable of holding canned and custom tunes, and the newer style X-3 only holds customs. Now when the newer style X-3 hit the market, that's when they introduced the SF3. They should of left the X-3 hold canned and custom and have the SF3 only hold custom. This way, Joe public won't get confused on which X-3 model they have, because both newer and older X-3's share the same part #3000.
Maybe they stopped putting the SF3 label on as to not confuse the public with the SF3 that is available for the 6.4. Most people look for a label when buying a product and not the part number. If you look at SCT website, you will notice that for our SCT devices it don't state a certain year motor or vehicle in the advertising header, this is because our model SCT device will work with a multitude of Ford vehicles. Now look at the devices for the 6.4, you will see in the advertising header that it's only for the 6.4 motor, this is because the 6.4 used a totally different mother board in the devices and won't work with any other vehicle.
2004 F350 CC DRW King Ranch
lilpooh is offline
The latest project Super04Duty The Parking Lot 10 01-31-2010 11:53 PM
Latest Brutus the Grey 6.7L Cummins (2007.5-2011) 13 02-01-2008 07:53 PM
Latest opinions on the SCT imported_Headlight 2008-2010 6.4L Engine Tuner Forum 74 11-20-2007 11:26 PM
Here is my latest innovation 1911 Guy 5.9L Cummins (2003-2007.5) 20 10-24-2007 07:09 PM
FYI: Latest Flash JSxFX4 2003-2007 6.0L Power Stroke 1 02-09-2007 11:09 PM
