Best tunes for 06 6.0 for towing heavy - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Whitetrash06350, this thread has received 3 replies and been viewed 10449 times.
post #1 of 4 (permalink) Old 12-12-2011, 03:20 AM Thread Starter
Does anyone make a good tune for pulling heavy 06 f350 6.0 4" dual exhaust bully dog programmer airmail. 4x4 crew cab king ranch. I pull trailers 3-4 times a week from 4k to 14k is there a system that can switch between better fuel mileage and pulling trailers.
Whitetrash06350 is offline
post #2 of 4 (permalink) Old 12-12-2011, 04:18 AM
If they make one, this would be it http://stealth-automotive.com/index....roduct_id=1386
I see ARP studs coming keep it under 25lbs of boost, i pull a 14k 5er and have no problem solo 18.4 pulling 9 You pay to play
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge CTS Expandable Pyro,AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Coolant Filtration System Delo ELC
Pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #3 of 4 (permalink) Old 12-17-2011, 04:14 AM
harry6.0's Avatar
My recommendation, stay with stock tuning or a very very mild custom SCT tow tune. You can make all kinds of good power with tuning, but for towing it's best to stay as close to stock as possible. Put a high power custom tune in and tow, and likely it won't be long before you are digging deep into your motor and pockets.
Harry
harry6.0 is offline
post #4 of 4 (permalink) Old 12-17-2011, 04:45 AM
As harry said you may need deep pockets with tunes because they are maxed out on HP now and i would never get a new one 08-12 because of the fuel pump system on them if it goes out it's about 10k.
2 stroker
3" dp-4" exhaust
Tymar Intake
What truck for towing heavy 5'er joe22790 Towing and Hauling 8 07-24-2011 02:37 AM
Towing Heavy Cargo daig1983 Duramax 2006-2007(LBZ & LLY) 1 01-10-2011 02:50 AM
Heavy towing on 210 tune & surging? 08STROKER6.4 2008-2010 6.4L Engine Tuner Forum 9 06-09-2010 07:48 PM
heavy towing opinions SSpeeDEMONSS 2003-2007 6.0L Power Stroke 16 11-09-2009 04:02 AM
Spooling a Big Turbo Towing Heavy ralphinnj 2003-2007 6.0L Power Stroke 17 05-19-2009 01:08 PM
