towing heavy W/ turbo and sticks - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Red Smurf, this thread has received 4 replies and been viewed 2266 times.
post #1 of 5 (permalink) Old 12-15-2011, 10:09 PM Thread Starter
I went crazy with the truck and now i want to tow heavy! I have II 225cc injectors and the VGT HO from elite. Right now i have no tune in it cause all i had was race tunes but I think the egt's are a little warm with the truck running stock and no trailer so I need some advice for keeping the egt's down when I have to yank around the tow hauler! Thanks
_____________________________________________
Red 2004 F-250 4x4
pro comp lift
innovative diesel SCT
ITP Regulated Return
magna flow exhaust
Red Smurf is offline
post #2 of 5 (permalink) Old 12-15-2011, 10:12 PM Thread Starter
oh and I have the APR Headstuds, 411 gears in the rears with stok tires, I did that to eep the rpms higher which has been helping towing small stuff but if i let her into od which she has the power to pull it the egts just get to high. So my temp solution has been to go fast enough to keep the tranny in 4th which has got me 2 tickets all ready.
Red 2004 F-250 4x4
pro comp lift
magna flow exhaust
post #3 of 5 (permalink) Old 12-17-2011, 03:57 AM
harry6.0's Avatar
1) What kind of egt's are you seeing?
2) Spooled/boosted airflow with less fuel will keep the egt's lower, lug it in overdrive, and they will climb, especially with 225's..
3) Need a custom tow tune to tone down the fuel flow. Could take several attempts to get it right, and even then it may still be high with 225's and a bigger turbo.
4) Mike(Nutty Professor)at KEM Performance, got my Powermax dialed in perfectly the first attempt.
Harry
harry6.0 is offline
post #4 of 5 (permalink) Old 12-25-2011, 04:37 AM
robs97z28's Avatar
this will also help, but just a little. about 200* on the egts.
http://www.summitracing.com/search/M...ow+performance
03 Excursion, Banks turbo back, K&N intake, 285/70R17 on Eagle alloys, purchased June '10
robs97z28 is offline
post #5 of 5 (permalink) Old 12-26-2011, 09:06 AM
Stuck in Commiefornia...
IdahoF350's Avatar
Aside from proper tuning, which is really a must have, you probably ought to consider more gear, 4.30s, 4.56s, or even 4.88s Get the RPM in overdrive up in the range of 2200-2400RPM at 55-60 with the small 32" tires. Then you can always jump up to 35-37" tires when your not towing if it's lifted a bit and keep the RPM down.
The F-550 I drive at work has 4.88s, and it needs them to move, but the poor old 7.3 turns 2500rpm to do 65mph. I doubt that 7.3 will see 500k, but at least the truck can move it's 20,000lb self and a trailer as needed.
2000 Excursion XLT 4x4
IdahoF350 is offline
Best tunes for 06 6.0 for towing heavy Whitetrash06350 2003-2007 6.0 Tuner Forum 3 12-17-2011 04:45 AM
Heavy towing with my Aggressive tow tune/PowerMax turbo carlson158 2003-2007 6.0L Power Stroke 24 02-22-2011 02:59 PM
Towing Heavy Cargo daig1983 Duramax 2006-2007(LBZ & LLY) 1 01-10-2011 02:50 AM
heavy towing opinions SSpeeDEMONSS 2003-2007 6.0L Power Stroke 16 11-09-2009 04:02 AM
Spooling a Big Turbo Towing Heavy ralphinnj 2003-2007 6.0L Power Stroke 17 05-19-2009 01:08 PM
