Sct and EGR valve? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bootcamp, this thread has received 16 replies and been viewed 4855 times.
post #1 of 17 (permalink) Old 12-23-2011, 04:10 PM Thread Starter
bootcamp's Avatar
Sct and EGR valve?
Please don't beat me up to bad for asking this question, but do the canned tunes on these SCT programmers turn off the EGR valve?
TIA
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline
post #2 of 17 (permalink) Old 12-24-2011, 02:15 PM
harry6.0's Avatar
Nope. Most all tuning devices off the shelf have to stay within the legal limits for emission laws. Unless its a device that allows you to perform your own custom tuning, like pro racer software.
Harry
harry6.0 is offline
post #3 of 17 (permalink) Old 12-24-2011, 02:38 PM Thread Starter
bootcamp's Avatar
Thanks Harry,
I have been running the canned tunes from my SCT for a couple of years now due to the fact that I change my gears out on my truck and the custom tunes i have from Bill @Dfuser were for the stock 3.73 gears. So with this, I havent wanted to run the customs tunes since its going to affect the shifting points and have been sticking to the canned tunes. I have been wondering if this could be affecting my fuel milage with the egr not being turned off. So I need to get off my lazy but and get some new tunes that accomadate my new gearing and turn off the egr.
USMC 87-90 MOTOR-T
bootcamp is offline
post #4 of 17 (permalink) Old 12-25-2011, 01:40 AM
harry6.0's Avatar
Your welcome Bootcamp, always glad to help if I can. With your 4:10 gearing and 35" tires, what rpms are you seeing at say 70mph cruising down the highway? Just curious, because I am running 35"s with the 3:73 gearing.
Harry
harry6.0 is offline
post #5 of 17 (permalink) Old 01-03-2012, 01:39 PM
Harry, what RPM do you see and what kind of MPG do you get?
lenzhotrod is offline
post #6 of 17 (permalink) Old 01-08-2012, 01:36 AM
robs97z28's Avatar
I guess that is a secret! lol He might have to kill you if he told you. lmao
03 Excursion, Banks turbo back, K&N intake, 285/70R17 on Eagle alloys, purchased June '10
robs97z28 is offline
post #7 of 17 (permalink) Old 01-08-2012, 02:20 PM Thread Starter
bootcamp's Avatar
Harry, when I get home in a couple of days and get beck in my truck, I will log it and post it for you.
USMC 87-90 MOTOR-T
bootcamp is offline
post #8 of 17 (permalink) Old 01-09-2012, 01:44 PM
harry6.0's Avatar
Sorry for the delay in reply guy's, haven't checked this thread till now. Anyhow, I see 2000rpm at 75mph, 1900 at 70mph, 1800 at 65mph. My mileage around town driving with winter fuel and winter conditions it can drop as low as 13.5mpg and go as high as 17 on the highway. With summer fuel and warmer conditions everything goes up, around town 15-16 and highway 18 and even 20 on rare ocassion. Around these parts it's hard to get the trucks T-stat to open in winter, my usual coolant temps are around 166F and ocassionally 174F if we tow, that effects mileage the most, not being able to get up to operating temps. I have thought about getting a winter front for the trucks grill, or at least a piece of cardboard stuck in there.
Harry
harry6.0 is offline
post #9 of 17 (permalink) Old 01-09-2012, 08:55 PM
Yes, in the adjustable option in the canned tune is a setting for egr on or off, it does not actually shuth the process it just shuts the light off that it throws when you do the physical delete
jgrouppy is offline
post #10 of 17 (permalink) Old 01-10-2012, 02:18 AM
What kind of exhaust temps are you seeing? Mine is roughly 10 X MPH.
24 valve head on a 12 valve? Hotrodx199 5.9L Cummins 12 Valve (1994-1998.5) 11 05-24-2009 12:02 AM
Air shutoff valve and 3 way fuel valve '05Supersmoker Sled Pulling 2 02-05-2008 12:23 AM
cummins 60 lbs valve springs 12 valve imported_machine2 Whats Been Sold 0 05-08-2007 12:58 AM
1998 24-valve compared to 12-valve Michael 5.9L Cummins (1998.5-2002) 1 06-28-2006 05:22 PM
24 Valve p-pump vs 12 Valve ob1kobi Dodge Performance Forum 33 10-31-2005 03:13 PM
