SCT Tuner Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by frankmako, this thread has received 5 replies and been viewed 2021 times.
post #1 of 6 (permalink) Old 01-28-2012, 12:22 AM Thread Starter
SCT Tuner Question
I got a used 2004 truck last year with 88k miles. This year I got a SCT 3015 tuner. When I check the vehicle information it reads; Strategy VXBC9N8 & TQBF0NA. When I load the Performance tune into the vehicle it reads Engine Strategy - VXBC9N8 and Trans Strategy - TQBF0NA. They are the same. Should the strategy numbers change when I loaded a tune? Does this mean that the vehicle had the Performance tune already loaded in it? The unlock went from 5 to 4 after the first time I used the tuner.
frankmako is offline
post #2 of 6 (permalink) Old 01-28-2012, 01:14 PM
harry6.0's Avatar
Strategy numbers shouldn't change. Unlock means that it's recorded your vehicles vin into the device. If you used the sct in a different truck, you would lose another unlock. Do this enough times, and all unlocks are gone, then the tuner is locked and won't work, unless you send it in to be unlocked, which they charge for. So right now you still have 4 unlocks left, it will remain at 4 unless you use the sct in a different truck other than yours. You can load and unload all the tunes you want in your truck, and you should still remain at 4 unlocks.
Harry
harry6.0 is offline
post #3 of 6 (permalink) Old 01-29-2012, 11:35 PM Thread Starter
thanks harry6.0.
post #4 of 6 (permalink) Old 02-10-2012, 03:57 AM
New Dude her in da garage
Send a message via Yahoo to fredz04f250
Actually you can use it in any truck that is the same as your own with out using any unlocks.
fredz04f250 is offline
post #5 of 6 (permalink) Old 02-10-2012, 04:14 AM
lilpooh's Avatar
Nope, the SCT reads your VIN, and locks onto it, so when you go and return to stock tune, it has stored your VIN, now when you go to use it on another truck, it sees that it's not the same VIN and uses up a unlock.
Once it has a stored VIN, it is locked to that truck. This truck can now put in and take out as many tunes as it wants an not use any unlocks.
Recap, the SCT uses up a unlock when it sees a different VIN.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #6 of 6 (permalink) Old 02-10-2012, 04:20 AM
Thats funny I just threw a preloaded tune on a friends truck for him to check out he tried it out for a few days then I returned it to stock and didnt lose any unlocks maybe mine is special
tuner question? ehopp88ss Common Rail 21 11-23-2012 01:31 AM
Dp-tuner question JuststrokeIT 1994-2003 7.3L Chips & Tuners Forum 9 01-16-2009 12:20 AM
DP tuner/ECM question? 99fordtruckguy 1994-2003 7.3L Chips & Tuners Forum 1 03-20-2008 05:23 AM
another tuner question Sweiny GM Performance Forum 3 01-15-2007 08:32 PM
Tuner question... $DIESEL 2003-2007 6.0 Tuner Forum 21 11-23-2006 08:55 PM
