Tuner Questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Texas_stroker23, this thread has received 7 replies and been viewed 4436 times.
post #1 of 8 (permalink) Old 03-01-2012, 03:16 AM Thread Starter
Tuner Questions
hey guys im new to the forum and I have a 03 6.0 and am currently running an older edge juice with the evolution monitor. I have been looking at the sct itsx but am wondering if there has been any problems with it etc...Also i was looking into custom tunes but my truck is on 40s and i dont want to get too wild and starting breaking stuff...what is yalls opinions on this? also ive been talking to innovative but is there someone else better?
thanks for the inputs
Texas_stroker23 is offline
post #2 of 8 (permalink) Old 03-06-2012, 06:12 AM
harry6.0's Avatar
Best thing is to buy the SCT tuner from the same source thats providing the custom tuning. I myself like KEM performances tuning, they are very good. Talk with Mike at KEM, he will be able to provide sensible options for you to choose from.
Harry
harry6.0 is offline
post #3 of 8 (permalink) Old 03-08-2012, 06:36 AM
lilpooh's Avatar
The iTSX is the newest product from SCT, not too many member on this forum and other forums using it. I know of three members (other forum) that are using it, one of them has a issue where the iTSX has not worked after he installed his tune. IMO, your better off getting either a SF3 or X-3 because these two models have been around quite awhile.
You can contact a authorized SCT tune writer and buy a new SF3 or X-3. The SF3 will hold 5 canned tunes and also hold 3 custom tunes, but the custom tunes will have to be bought separately. The X-3 will hold 3 custom tunes, some tune writers offer a package deal that include the 3 custom tunes in the price.
If your wanting to save some money, you can check your local Craig's list, eBay, or forums for a used unit. Then purchase custom tunes from a tune writer. Typically a used SF3/X-3 that is unlocked and has unlocks left will go for $225-$275. You can read about buying a used SCT in this link.
https://www.thedieselgarage.com/forum...d.php?t=112106
Now your gonna need a monitor/gauge solution. Have you checked out the DashBoss for the iOS devices. The DashBoss for the 6.0 is now live and working great. Here is the link.
https://www.thedieselgarage.com/forum...d.php?t=114680
2004 F350 CC DRW King Ranch
lilpooh is offline
The Following 2 Users Say Thank You to lilpooh For this addition to TDG:
harry6.0 (03-10-2012), Sader (03-16-2012)
post #4 of 8 (permalink) Old 03-10-2012, 01:39 AM Thread Starter
Thats great info....So the only reason i wanted to run the itsx is because i can do it all on my phone BUT i deffinatly do not want something that is going to mess up or not work half the time or all the time. I was thinking from what i heard was having eric at innovatiove write me tunes because my truck is on 40s and he can compensate for that shift points, power, fuel mileage...etc vs. the canned tunes unless there is someone that writes them that is better. Ive heard people having preferences on the sf3/x-3...is there any pro's & con's on either?
As far as monitoring goes I have pillar guages monitoring boost,pyro,trans temp...is there something i should have that i dont have? im kinda new to this thats why theres alot of things im unsure on. I really appreciate your input also
post #5 of 8 (permalink) Old 03-10-2012, 05:21 AM
lilpooh's Avatar
A new X-3 will only hold 3 custom tunes, which is fine because once you try a custom tune you'll almost never use a canned tune again.
The SF3 holds 5 canned tunes and also hold 3 custom tunes.
Any well known tune writer can write tunes to suit your needs. Members ask all the time, who's the best. Well it comes down to personal preference, driving style, and if your truck likes the tunes. Tunes written for one truck may act a little different on another truck (different strategy, gear ratio, tire size, ect, ect)
With the 6.0, it's important to monitor EOT,ECT, fuel psi, and FICMv. If your running tunes then EGT. Also if you tow heavy, TFT.
Monitoring ECT/EOT, if the delta is 15* or more, start looking at replacing your oil cooler because it blocked up in the coolant passage side of the oil cooler. This will cause a domino effect, because coolant is restricted from reaching the EGR cooler. The EGR cooler fails/ruptures and you end up getting coolant into the cylinders. Now coolant wont compress in the cylinders so the weakest link is the head bolts. The head bolts will stretch causing headgasket failure.
Fuel psi, when fuel psi drops below 45 psi from idle to WOT, your doing damage to the injectors.
FICMv, when FICMv drops below 46v while cranking or engine running, your also hurting the injectors.
lilpooh is offline
post #6 of 8 (permalink) Old 03-19-2012, 02:00 PM Thread Starter
Ok well I just had the studs gaskets deletes etc done a couple months ago....so out of all of those things what would be the most important to monitor like fuel psi or the FICMv? Reason im asking is because i will change my pyro gauge to one of those two....Also what does EOT and ECT stand for?
post #7 of 8 (permalink) Old 03-20-2012, 05:36 AM
harry6.0's Avatar
EOT...engine oil temp
ECT...engine coolant temp
TFT...transm fluid temp
I would still monitor egt's. Myself, I mostly monitor EOT...ECT...ICP...Charging Voltage... on my ScanGauge2, which only allows 4-choices at a time on the tiny screen, but I can scroll through to look at many other choices such as ficm voltages, ipr readings, TFT and so on, and my 2-analog gauges read egt's and boost always. My opinion, the better you monitor these motors, the better you know your truck, which can help tremendously when it comes to issues that may arise or be prevented. This is especially true if you run modified and tuned.
Harry
harry6.0 is offline
post #8 of 8 (permalink) Old 03-26-2012, 05:00 AM Thread Starter
Harry
Well i guess ill leave it the way it is and look into the scangauge2's
I appreciate the help
Tuner questions justindacey 2008-2010 6.4L Engine Tuner Forum 6 09-30-2010 04:51 AM
dp tuner questions camojeeper 1994-2003 7.3L Power Stroke 7 02-15-2008 01:42 PM
dp tuner questions Whiteghost 1994-2003 7.3L Chips & Tuners Forum 3 07-30-2007 01:38 AM
6.0 tuner questions ratherbestrokinthancummin 2003-2007 6.0L Power Stroke 9 12-27-2006 04:37 AM
Tuner questions Diesel Dog 2003-2007 6.0 Tuner Forum 2 09-09-2006 04:16 AM
