03 6.0L high egt - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by OffKilter, this thread has received 4 replies and been viewed 2787 times.
post #1 of 5 (permalink) Old 05-25-2012, 02:00 AM Thread Starter
Truck pullin' S.O.B.
OffKilter's Avatar
Images: 13
03 6.0L high egt
2003 F-350 6.0L 6speed, k&n FIPK, MBRP 4" downpipe back stock downpipe, Edge Juice with additude. Last week I cleaned my turbo cuz boost was non exsitent, now even on stock egts hit 1000 with out hardly getting on the throttle. the turbo is spooling now but is still kinda laggy, and when cruising at about 2200 rpms or so in 3rd or 4th it surges. any help?
1999 F-250 Lariat, Red, Super Cab, Short Box, 6.8L V-10
2003 F-350 XLT Regular Cab Long Box 6.0L 6-speed, tinted windows, push bar, 4inch MBRP exhaust, Edge Juice w/ attatude.
1969 F350 "The Shillelagh" future pulling truck, 428ci, 4-speed, 4:10 gears.
OffKilter is offline
post #2 of 5 (permalink) Old 05-25-2012, 01:59 PM
harry6.0's Avatar
Turbo vanes are probably still sticking. My original 03' turbo vanes were sticking and causing high backpressure and overboost. When I took it apart to clean it, I discovered the exhaust housing and unison ring were worn. I cleaned and lubed it anyway and put it back together to buy some time, as my Powermax was already on order, it worked great for about 2 days, then started acting up again. You can purchase a new housing and unison ring if yours are worn like mine was, as that may be a cheaper route to go for getting it working right again, but also make sure you don't have any exhaust leaks in the y up-pipe feeding the turbo. If you decide to go with a new turbo, such as the Garrett Powermax VGT, then custom tuning is needed to get it working right, but if you go with a stock replacement then you won't need custom tuning.
Harry
harry6.0 is offline
post #3 of 5 (permalink) Old 05-25-2012, 11:03 PM
lilpooh's Avatar
With an '03 motor, sometimes after the batteries have been disconnected for a amount of time, you will need to do the VGT relearn procedure.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #4 of 5 (permalink) Old 05-26-2012, 09:20 PM Thread Starter
OffKilter's Avatar
Images: 13
i couldn't tell you the last time i had the batteries disconnected.
post #5 of 5 (permalink) Old 10-22-2012, 09:08 PM
Send a message via AIM to F350CCFX4
It's been awhile, but have you had the FICM checked and a Power Balace down on the injectors? High EGTs on the 03 and early 04 sometimes lead to a bad injector or 8.
Honor, Grace and Dignity. Remeber these?
'04 6.0 CC, SRW F350 with Doug's toons. Airaid, Turbo back MBRP 3.5 down to 4, Banks intercooler
Parts in a box that need to be installed:
Firestone Ride Right kit.
Lighter foot.
F350CCFX4 is offline
how high is to high of water temp? and how hard are the up pipe gaskits to change? outlaw108 1994-2003 7.3L Power Stroke 8 08-22-2011 12:06 AM
high egt yadaddy99 2003-2007 6.0L Power Stroke 7 08-13-2010 10:04 PM
NTC 400 BC1 - Feels like it has a high speed / high load miss bell206b3 Medium and Heavy Duty 20 01-01-2010 03:21 AM
egt to high SOOTBANDIT 6.7L Cummins (2007.5-2011) 13 04-02-2009 09:26 PM
High Idle & High Idle Kicker... Mopar1973Man 5.9L Cummins (1998.5-2002) 4 12-25-2008 02:36 PM
