Snows performance methanol injection question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tmoriarty19, this thread has received 6 replies and been viewed 2253 times.
post #1 of 7 (permalink) Old 07-12-2012, 10:38 AM Thread Starter
Tyler
I have an 06 6.0 with an sct tuner and 4" mbrp exhaust. I was talking to river city diesel about snows performance mpg maxx kit and they seemed to really recommend it. Theres not much on here but what i have found is alot of mixxed conflicting opinions. Does anyone have actual experience with this kit and how well it works?
tmoriarty19 is offline
post #2 of 7 (permalink) Old 07-13-2012, 06:37 AM
harry6.0's Avatar
There were some members from along time back that had some of these kits. RCD has alot of experience with 6.0L PowerStrokes, so they would likely know how it performs in a 6.0L. But remember, water/meth is a fuel, and you just don't want to over dose with it and cause high cylinder pressures especially if your not ARP studded. It will clean the intake and combustion chambers very well. If properly setup it can work very well in most diesel applications. Sorry can't offer much more than that, but maybe someone with experience running this setup will chime in.
Harry
harry6.0 is offline
post #3 of 7 (permalink) Old 07-14-2012, 03:10 AM
lilpooh's Avatar
I run the Stage 2 Snow W/M kit. Only has 2 injectors, where the stage 3 has 3 injectors. The stage 3 controller also has more user adjustments than the stage 2 controller.
I don't see any MPG gain with the stage 2. The stage 3 with its third injector comes on at 2 psi of boost and for the small injector, this is where you might gain MPG.
Seat of the pants power can be felt, even with just washer fluid. I mainly use W/M to keep EGT down when towing or running WOT.
So what do you want to know?
2004 F350 CC DRW King Ranch
lilpooh is offline
The Following 2 Users Say Thank You to lilpooh For this addition to TDG:
harry6.0 (07-15-2012), tjigger (08-27-2012)
post #4 of 7 (permalink) Old 08-27-2012, 05:47 PM
TDG Singles Outlaw #10
Lilpooh,
what brand washer fluid do you use?
i know its expensive but did you ever try the boost juice?
2006 Harley Davidson 4x4 F250 6.0L-PSD #02250
Bully Dog--Triple Dog w/Outlook, MBRP Turbo-Back 4in SS off-road Exaust, Airaid cold air intake,Zoodad, PDP Intake Elbow, FabTech lift W/ Dirt Logic 2.25 shocks, Moog Teflon Sway Bar Bushings, Nitto Terra Grappler tires, Line-X, Jason Camper Top, KC Light bar, Rigid Dully backup lights, Viper Remote Start Alarm, Eclipse TV/DVD/NAV, Custom TV in center console, JL 500/1 on 2 10W3's, JL 4ch on 5x7 Boston's,http://www.adamspolishes.com/, 2013 5x10 LOOK trailer Grey, 2015 Jayco 34RSBS Trailer.
Next Mods: Head studs(waiting for install),injectors, Steveracermod, Coolant Filter(waiting for install)
For Sale+++ Roll-N-Lock bed cover 6 1/2ft bed +++For Sale
https://www.thedieselgarage.com/galle...=9&userid=8088
TDG Singles Club #117
tjigger is offline
post #5 of 7 (permalink) Old 08-28-2012, 02:26 AM
strokin6L's Avatar
I love my snow stage II kit. I use nothing but winter blend winshield washer fluid....seems to work the best because the winter blend has more meth in it that summer blend. I've been using water injection for nearly 6 years and i love it.
strokin6L is offline
The Following User Says Thank You to strokin6L For this addition to TDG:
tjigger (08-28-2012)
post #6 of 7 (permalink) Old 08-28-2012, 06:25 AM
lilpooh's Avatar
Yep, same here. Winter blend washer fluid.
I've never bought the "boost juice", but I have mixed my own 51% distilled water with 49% meth.
lilpooh is offline
post #7 of 7 (permalink) Old 08-28-2012, 04:49 PM
thanks
tjigger is offline
methanol injection imported_machine2 5.9L Cummins 12 Valve (1994-1998.5) 2 04-11-2008 04:36 AM
Methanol and, or Propane Injection?? pedro_8149 7.3L and 6.9 IDI (Pre 1994) 5 08-11-2007 05:19 PM
Methanol injection 85ford 7.3L and 6.9 IDI (Pre 1994) 1 04-05-2007 06:32 PM
Methanol injection n2diesel 1994-2003 7.3L Power Stroke 7 07-19-2006 11:35 PM
water/methanol injection [email protected] 7.3L and 6.9 IDI (Pre 1994) 0 05-05-2006 06:29 PM
