SCR Xcellerator II died - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ALBOB, this thread has received 3 replies and been viewed 975 times.
post #1 of 4 (permalink) Old 12-10-2012, 07:49 PM Thread Starter
When I plug the unit in nothing happens, it's completely dead. I've used it as recently as two months ago to flash back to stock with no problems at all. Any ideas what could be wrong?
Rules? You mean there are rules for that?
ALBOB is offline
post #2 of 4 (permalink) Old 12-11-2012, 05:39 AM
harry6.0's Avatar
Not familiar with that module, but does it have a fuse inside?
Harry
harry6.0 is offline
post #3 of 4 (permalink) Old 12-11-2012, 06:17 AM
lilpooh's Avatar
Does your cig lighter work? The lighter and OBDII port share the same fuse.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #4 of 4 (permalink) Old 12-11-2012, 03:59 PM Thread Starter
Amazingly enough no, it doesn't. The wife just pointed this out the other day but since we only use it for the GPS I didn't give it much thought. Thanks for the tip. I'll report back after changing the fuse.
P.S. That's a typo in the thread title, it's an SCT unit. Damn fat fingers.
ALBOB is offline
PPE Xcellerator Hot+2 Jetmech Whats Been Sold 3 09-24-2009 10:50 PM
6.5 died again imported_Prodiesel 6.5L Diesel Engine 8 11-24-2007 01:41 AM
Possible ECM died now.. 02sprtcumns 5.9L Cummins (1998.5-2002) 2 01-15-2007 12:07 AM
Duramax LLY Hot+2 Xcellerator E.T. Eliminator 2004 - 2005 fwdcummins Whats Been Sold 0 01-03-2007 12:56 PM
it died.. AGAIN!!! DSI 2003-2007 6.0L Power Stroke 0 02-13-2006 05:46 AM
