Best software for Diagnosing bad injectors - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Tornsteel, this thread has received 1 replies and been viewed 1409 times.
post #1 of 2 (permalink) Old 01-12-2013, 10:50 PM Thread Starter
Tornsteel's Avatar
I'm going to be doing my HG's again and I've noticed that is sounds like one of my injectors sounds a little louder. Since I'm going to be pulling the engine apart I thought it would be a good time to fix a bad injector, if I have one. My question is what is a good way to find out if one or more are bad? I have heard about Auto Enginuity. Is this any good? Also if I did go this route would it be useful for other things? I had read some posts that its the next best thing to the IDS. Sorry if this has been covered but my computer is down and trying to do a search on my IPhone sucks. The symptoms I'm getting are what sounds like a noisy injector to the R bank (aspecially) after a cold start and a little bit of blue smoke after cold start. When the truck is warm the smoke is gone. I am using arch oil fuel and oil additive in it and have been for over a year.
Thanks guys.
2006 XLT 6.0, 72,000 miles. First owner. Build date 10/05, CC,LB,3.73LS,SRW,ISSPRO Pyro-Boost-Trans on the APillar,ARP Studs,Stock HG's,ELITE SCT Tadd's Tunes,Sinister SCT,Innovative tunes,EGR delete,4" turbo back dual exhst, zoodad, ccv mod, Coolant bypass filter, Cage leveling kit,upfitter high idle, running Amsoil 3000 with Archoil, 6.4 banjo's, Blue spring, 03 Turbo w/ 03 pedestal.
Issues: Rear main seal at 1'700 mls. EGR valve, EGR cooler and Oil cooler @ about 43k, Stock Head Gaskets @55k, Black Onyx HG's @72k.
https://www.thedieselgarage.com/galle...028_393362.jpg
Sean H
Tornsteel is offline
post #2 of 2 (permalink) Old 01-12-2013, 10:54 PM Thread Starter
Tornsteel's Avatar
Sorry wrong section.
Sean H
Bad Injectors ????? littlebigrig6.0 2003-2007 6.0L Power Stroke 0 08-14-2009 05:32 AM
think my injectors are bad again Tims02ford 1994-2003 7.3L Power Stroke 8 07-04-2009 02:35 PM
Bad injectors? Bad turbo??? NCcummins 5.9L Cummins (1998.5-2002) 20 01-13-2009 03:20 PM
need help diagnosing several problems Rake 1994-2003 7.3L Power Stroke 4 02-14-2008 11:11 PM
3 bad injectors FordRacing200 2008-2010 6.4L Power Stroke 11 05-23-2007 05:41 PM
