egr delete whats tuner to buy? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kanarman, this thread has received 13 replies and been viewed 4357 times.
post #1 of 14 (permalink) Old 07-19-2013, 03:35 AM Thread Starter
2006 new oil cooler egr delete. No blockoff plate gettin the egr codes
I dont have any aftermarket guages. I do have afe cold air and filter
And silverline 4.inch strait pipe.
Thanks in advance
kanarman is offline
post #2 of 14 (permalink) Old 07-19-2013, 04:02 AM
Weld engineer's Avatar
SCT X3
Check out the vendors. You usually get 3 custom tunes when you buy from most places. They will adjust it for an EGR delete. You need studs for hot tunes.
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
post #3 of 14 (permalink) Old 07-19-2013, 01:39 PM
harry6.0's Avatar
Weld is correct, a custom tuned SCT X3 is what you want for the 6.0 Powerstroke, it tunes the engine and transmission to match. I use Mike at KEM, heres a link.....
http://www.kemperformance.com/Produc...p?ProductID=32
Harry
harry6.0 is offline
The Following 3 Users Say Thank You to harry6.0 For this addition to TDG:
kanarman (07-25-2013), Nitelord (07-19-2013), Weld engineer (07-19-2013)
post #4 of 14 (permalink) Old 07-21-2013, 03:40 PM Thread Starter
Thanks guys I think I am going to place my order today. Before I do could or should I purchace the livewire with the screen rather than the handheld x3?
kanarman is offline
post #5 of 14 (permalink) Old 07-22-2013, 02:08 PM
harry6.0's Avatar
For myself, I would rather have the SCT X3 and additionally purchase a ScanGauge2 for monitoring the critical engine/transm data. The livewire has some nice handy features, but won't read all the data like a ScanGauge2 does. ScanGauge2 is not a tuner, but only cost about 160.00 and reads nearly everything important for the 6.0 once the X-gauge features are coded in.
Harry
harry6.0 is offline
post #6 of 14 (permalink) Old 07-23-2013, 02:55 AM Thread Starter
Ok Harry I did it I placed my order got the SCT X3 from kem. I will get a scanguage in the near future.
thanks again Harry and also a thanks to you Weld Engeneer
kanarman is offline
The Following 2 Users Say Thank You to kanarman For this addition to TDG:
harry6.0 (07-23-2013), Weld engineer (07-23-2013)
post #7 of 14 (permalink) Old 07-23-2013, 04:51 AM
Harry
The Following User Says Thank You to Weld engineer For this addition to TDG:
post #8 of 14 (permalink) Old 07-25-2013, 10:47 PM
ADMIN/MAFIA
neeltburn's Avatar
Add A Pyrometer to the list, While I agree with Harry who is far better a the 6.0L Stuff than I am. I still suggest a Boost, Trans Temp and Pyro when running aftermarket tuning. The boost and Trans Temp will be far more accurate than the cluster and the Pyro will let you monitor your EGTs. That will also free up the scan gauge II to Display ECT over EOT and FICM Voltages. Just my thoughts.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #9 of 14 (permalink) Old 07-25-2013, 10:54 PM Thread Starter
I will do. I am trying to figure out what to set the tire Rpm to match the 3.73 gear to
285 /70/ 17s ? stock 660 ?
kanarman is offline
post #10 of 14 (permalink) Old 07-26-2013, 12:43 AM
Scangauge II will give you trans temp and inferred boost. I run an analog boost gauge from autometer and a digital pyro from autometer. Honestly the cooling system on the torqshift is amazing most guys report it runs at temp most of the time. It has a thermostat in it and once it opens the external cooler brings it in check fast. Overall I agree with neel I just personally don't watch my tranny temp much because it doesn't really ever get hot.
FICM tuning is where you can quickly run into pyro temp issues.
Wes
EGR off in tune or EGR delete. whanner 2003-2007 6.0 Tuner Forum 13 06-23-2013 06:34 PM
EGR Delete VrS EGR Bypass mattsn 2003-2007 6.0L Power Stroke 2 01-01-2011 06:22 PM
Egr CEL on after EGR delete jeffro22 2003-2007 6.0 Tuner Forum 57 04-12-2010 12:59 AM
SCT 9625 OR tuner '08 0r '09 6.4l Delete tuner $450 shipped! 4613 Whats Been Sold 1 01-02-2010 01:08 AM
Edge Juice, EGR Delete,SCT, Wheels & Tire, Liberator Egr Delete 760 PSD Whats Been Sold 3 04-22-2008 10:45 PM
