ECT/EOT Delta Help. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by luv2brode, this thread has received 31 replies and been viewed 12160 times.
post #1 of 32 (permalink) Old 05-05-2014, 10:08 PM Thread Starter
ECT/EOT Delta Help.
ok I have a early 2004 ( call it 2003) f250 and I got a scan gauge and am seeing some decent difference between eoc and ect like 20 degrees running around town. not noticing any leaking and no residue at degas bottle. I need to check my temps on a cold motor, to make sure not a sensor issue.
and on to the questions, I have been looking and finding conflicting or confusing info.
I would love to replace the oil cooler with the bpd set up/ money wont let it happen right now.
I read there is a new oem style oil cooler, what is up with this, is it better/ last longer?
what kind of life are people getting with oil cooler replacement/ im seeing 300-50000?
guessing I need to flush and replace thermostat.
dumping my money into a head gasket stud kit, with bpd egr cooler and associated pieces. maybe if I can get 50000 out of this cooler I can then afford the bpd set up.
I also see other cooler replacement systems, any ideas, seeing mixed reviews
any and all input appreciated
luv2brode is offline
post #2 of 32 (permalink) Old 05-06-2014, 07:22 PM Thread Starter
thinking I may change plans and go with the bpd oil cooler and egr cooler
post #3 of 32 (permalink) Old 05-07-2014, 01:35 AM
Weld engineer's Avatar
Your EGR cooler and/or your oil cooler is plugged. Luckily you may have caught it before oil cooler splits and puts oil in your coolant which is a real pain to clear out.
OEM oil cooler replacement is fine if you do the following:
Delete EGR or install bulletproof version. Don't go OEM.
Install coolant filter
Flush coolant and/or switch to ELC like CAT.
Keep in mind you will need to get custom tuning via an SCT to get performance back if you delete the EGR.
I think your topic title isn't catching people's eyes. It's better to state the issue to get attention. Sometimes the "help" ones get overlooked.
Good luck. Been there done that.
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
post #4 of 32 (permalink) Old 05-16-2014, 05:35 AM
ADMIN/MAFIA
neeltburn's Avatar
Thread Title changed to attach the 6.0L Gurus, Wes good suggestion, also looks like you have a good start on explaining the problem but I am just one of them Tractor Drivers what do I know about the V designed motors. :
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
The Following 2 Users Say Thank You to neeltburn For this addition to TDG:
harry6.0 (05-17-2014), Weld engineer (05-16-2014)
post #5 of 32 (permalink) Old 05-17-2014, 04:25 AM
harry6.0's Avatar
Before condemning the oil cooler completely...
1. ECT/EOT deltas need to be checked with a fully warmed up engine at operating temperature and cruising steady down a relatively flat highway at 60-70 mph.
2. Once you are cruising...you should not see the EOT more than 15 degrees higher than the ECT.
3. For instance...ECT 195F / EOT 204F this is ok.
4. For instance...ECT 195F / EOT 214F this is not ok.
5. If you are towing and/or going up a long grade, then EOT can become elevated over the 15 degree delta for short periods, but should drop back down once you get back into a normal flatter driving route.
Harry
harry6.0 is offline
bootcamp (05-24-2014)
post #6 of 32 (permalink) Old 05-22-2014, 02:56 PM Thread Starter
cool so bullet proof diesel egr cooler and oem oil cooler for this time and a coolant filter w elc coolant. ill save the bpd oil cooler for next time, given track records
thanks all
post #7 of 32 (permalink) Old 05-28-2014, 11:57 PM Thread Starter
ok so can the oil cooler come out w/out pulling intake, seen a couple places that it can just looking for confirmation. checking to see if I will be able to skip some of the work when putting bpd cooler on.
thanks
post #8 of 32 (permalink) Old 06-29-2014, 12:48 AM Thread Starter
ok so got my parts in who wants to help install?
post #9 of 32 (permalink) Old 06-29-2014, 01:01 AM
Be there in 2 hours. Have cold beer.
post #10 of 32 (permalink) Old 07-11-2014, 10:03 PM
Me too, if I'm not there on time go ahead and start without me.
lenzhotrod is offline
The Following User Says Thank You to lenzhotrod For this addition to TDG:
Weld engineer (07-11-2014)
Anyway to check ECT & EOT without a module? Tommyboy 2003-2007 6.0L Power Stroke 10 01-09-2012 08:40 PM
ECT and EOT installation location headviking 2003-2007 6.0L Power Stroke 0 09-14-2010 05:14 AM
EOT and ECT difference barnbridge 2003-2007 6.0L Power Stroke 17 08-16-2009 09:08 PM
Acceptable delta between IAT1 and IAT2 rabidsnowmobile 2003-2007 6.0L Power Stroke 3 02-13-2008 04:58 PM
Diablo Delta Flip Chip For Sale imported_CarterKraft Whats Been Sold 0 07-09-2007 12:13 AM
