Need help 6.0 no start,,, - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by UnderpressureNM, this thread has received 1 replies and been viewed 1348 times.
post #1 of 2 (permalink) Old 05-24-2014, 12:40 AM Thread Starter
Underpressure76nm
Question Need help 6.0 no start,,,
Rebuilt ipr 2285 code a week before it died for good, scanguage shows icp is good, put new oil cooler in and egr delete while I had it apart, ficm showed 47 then dropped as low as 23 when cranking,,,need help
UnderpressureNM is offline
post #2 of 2 (permalink) Old 05-24-2014, 04:16 AM
harry6.0's Avatar
Ficm should never drop below 46v, and one that drops that low will most definitely cause a no start.
http://www.ficmrepair.com/
Harry
harry6.0 is offline
UnderpressureNM (05-24-2014)
Tags
6.0, no start, powerstroke
Strange Cold start/no start/start changexlt 2003-2007 6.0L Power Stroke 7 12-23-2008 10:00 PM
Rough start and white smoke at cold start? bassn_07 2003-2007 6.0L Power Stroke 11 03-02-2008 11:57 PM
04-17-13 Hard Start Or No Start - Gpcm Connector Service Kit Available - 6.0l Engine Squatch Ford Oasis requests 0 03-23-2007 12:55 PM
CRANK NO START, HARD START, RUNS ROUGH AT IDLE - 6.0L 2005 F, E-Series,and Excursion PSDPlayer 2003-2007 6.0L Power Stroke 0 10-08-2005 08:32 AM
