5R110 Erratic shifting - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jdydiesel, this thread has received 1 replies and been viewed 3025 times.
post #1 of 2 (permalink) Old 02-23-2015, 02:25 AM Thread Starter
Dually Club #3
jdydiesel's Avatar
Hi Guys,
I need some help. I recently started experiencing erratic shifting. Finally got a code P0766 for the direct solenoid. I replaced it and the EPC solenoid with aftermarket units. Also converted to the 08 filter and deeper pan. Just took it for a test drive and no better. In fact it is probably worse. It shifts very hard from 3-5 and then downshifts and the does the hard 3-5 shift again. When I get it calmed down and into 5th it will then downshift again. I now just got a code P0700. Anyone have any ideas? Or am I screwed and its rebuild time?
FYI it's an 06 dually tuned by innovative. It does this tuned or stock
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
post #2 of 2 (permalink) Old 02-25-2015, 05:25 AM
harry6.0's Avatar
Which type transm fluid was in the transm when the problem started ?
Which type fluid is the current fill ?
Mercon LV or Mercon SP ??
There has been some controversy about Ford now recommending Mercon SP again after they said earlier that Mercon LV was the approved replacement for SP because it was not going to be produced anymore, but now it is again.
All this may have nothing to do with your transm faults, but how did the fluid look in the bottom of the original pan when it was off...lots of small metallic shiny particles?...Burn't smelling fluid?
If so on either of the above , then yes, it's rebuild time.
I'm still running Mercon LV but will be switching back again to the SP. I have not had any issues so far with the LV, but one never knows.
Harry
harry6.0 is offline
Torqshift 5R110 shifting into 4th/ video amdriven2liv 2003-2007 6.0L Power Stroke 4 02-21-2015 07:22 AM
12 valve new tranny shifting erratic bluedog 5.9L Cummins (1998.5-2002) 0 03-07-2008 01:31 PM
5r110 shifting issues BACK jdydiesel 2003-2007 6.0L Power Stroke 41 12-08-2007 01:51 AM
Automatic Trans Erratic Shifting hdcolo General Dodge Discussion 0 10-14-2007 08:40 PM
5R110 shifting issues jdydiesel 2003-2007 6.0L Power Stroke 12 07-18-2007 02:00 AM
