Injectors and boost pressure - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by lenzhotrod, this thread has received 3 replies and been viewed 2082 times.
post #1 of 4 (permalink) Old 05-19-2015, 11:35 PM Thread Starter
On my most recent build I installed a new compressor wheel on my stock 2003 turbo and my pressures increased from a normal high of 28 psi to a new normal high of 32 psi. Now I installed some injectors I made up (true 165 with 25 nozzle) and now my turbo pressures are up over 40psi. My thinking is I am producing more fuel, producing more exhaust, spinning the turbo faster? Is this correct? Why have I not read of others with higher turbo pressures after injector changes?.
lenzhotrod is offline
The Following User Says Thank You to lenzhotrod For this addition to TDG:
harry6.0 (05-22-2015)
post #2 of 4 (permalink) Old 05-22-2015, 01:50 PM
harry6.0's Avatar
Your analogy sounds logical to me Len. The turbo may be overspeeding, that is kinda the theory on Powermax turbos, they don't over speed as easily.
Truck must run really strong at those boost levels.
What kind of compressor wheel are you running? 40psi has been known to be a reality in other trucks with different combinations.
32-35 psi can be achieved with stock injectors + turbo + custom tuning, so with your combo it's really spooling things up good.
Curious, what kind of max egt's are you seeing?
Maybe different custom tuning would help?
Harry
harry6.0 is offline
post #3 of 4 (permalink) Old 05-23-2015, 03:21 AM
Weld engineer's Avatar
Second the EGT question. I assume you have studs that's allotta boost
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
post #4 of 4 (permalink) Old 05-23-2015, 03:50 AM Thread Starter
The high boost is why I brought this up. Yes it is studded.
Weld engineer (05-23-2015)
Drive pressure VS. Boost pressure hayjayhorses 12 Valve Performance 6 02-02-2014 06:54 PM
Boost pressure 7.3Lforlife 1994-2003 7.3L Power Stroke 2 03-14-2012 02:19 AM
Boost pressure??? Sloth 2003-2007 6.0L Power Stroke 25 07-26-2007 05:22 AM
Any way to boost Low pressure oil pressure? CSIPSD 1994-2003 7.3L Power Stroke 6 10-10-2006 02:15 AM
Boost pressure ovruigo 2003-2007 6.0L Power Stroke 10 09-26-2006 05:09 AM
