Livewire TS Equation Help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Super 05, this thread has received 1 replies and been viewed 1439 times.
post #1 of 2 (permalink) Old 06-27-2016, 07:43 PM Thread Starter
Super 05's Avatar
Has anybody figured out how to enter a new equation on the Livewire TS to monitor fuel psi on analog 1 wire. Not on data logging but for the usual gauge setup while monitoring. The equation I need is (v*25)-12.5.
2005 F350 CC SB Lariat 4x4. 2" leveling kit up front, SCT Livewire TS. Magnaflow 4" Turbo back exhaust with Kitty delete. ARP Headstuds, EGR deleted. Air Dog 2 165.
Super 05 is offline
post #2 of 2 (permalink) Old 07-17-2016, 04:58 AM
harry6.0's Avatar
I don't have any experience with a livewire ts...but, and I'm sure you know this already, there is no fuel psi sensor on a 6.0L unless you install one on the secondary fuel filter bowl test port plug.
Myself, I have a sensor and stepper motor electronic gauge in the cab to read fuel psi.
I assume you are trying to use the livewire as your gauge for an analog fuel pressure sensor signal. Sorry, not much help.
Harry
harry6.0 is offline
X3 or Livewire gwh 2003-2007 6.0 Tuner Forum 5 02-15-2008 03:02 PM
Livewire Help!!! 03ford 2003-2007 6.0 Tuner Forum 3 08-29-2007 11:24 PM
livewire 05ex 2003-2007 6.0L Power Stroke 3 07-17-2007 04:00 PM
Livewire from DJ's firecat 2003-2007 6.0 Tuner Forum 6 07-03-2007 04:38 AM
livewire q's ncbowhunter 2003-2007 6.0 Tuner Forum 10 05-11-2007 03:28 PM
