6.0 Tec 6 Nightmare - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DLA, this thread has received 8 replies and been viewed 1287 times.
post #1 of 9 (permalink) Old 08-16-2006, 05:57 AM Thread Starter
DLA
Exclamation 6.0 Tec 6 Nightmare
Hi. is anyone running the tec 6 with the new 06e17 with the SCT Xcalibrator2? My truck is very erratic and seems to be doing what it wants to at times, especially in regards to fueling and shift points. Another Question I have is can I get someone to freaking put my truck back to another flash, utilize the EBP AND GET SOME PIECE OF MIND?! Doug, DJ, Or Eric,- Any advice?
DLA is offline
post #2 of 9 (permalink) Old 08-16-2006, 01:33 PM
InnovativeDiesel's Avatar
Images: 1
It's no problem. I have TEC6 flashed onto one of our business trucks and it runs strong...actually very strong. Is it running bad stock? Could be another issue.
InnovativeDiesel is offline
post #3 of 9 (permalink) Old 08-16-2006, 01:46 PM
Dalpilot's Avatar
Images: 1
I have a TEC6 from Innovative that is running very strong, and smooth!
Dalpilot is offline
post #4 of 9 (permalink) Old 08-16-2006, 02:14 PM
I have dyno'd trucks with the TEC6 flash and they are making just as much power as before. Sounds like you just need some tweaking on the files.
Tadd
Tadd Layton - Elite Diesel Engineering SCT Tuner for 6.0L/7.3L Ford using cylinder pressure measurements for peak power and engine reliability. www.elitedieseleng.com
Powering some of the most powerful 6.0s & 6.4s
VGT-SSThe originator, since January 2005.
Fast-6.0 is offline
post #5 of 9 (permalink) Old 08-16-2006, 02:28 PM
The flash could have been done wrong, I had a truck with a tec6 and it gave me nothing but problems, put in a differnt flash and it went away. I think when the techs install the flash sometimes they screw it up somehow, might just reflash it again.
bean is offline
post #6 of 9 (permalink) Old 08-16-2006, 02:35 PM
fordt
I agree bean, my '03 had been reflashed once and the tech screwed up, never ran right for about 2 weeks, went to tech that knew what he was doing....no more problems at all:Thumbup:
post #7 of 9 (permalink) Old 08-16-2006, 10:10 PM
Window Licker
I will second that on the flash being screwed up. I for one am one of the people who had one screwed up and never knew it till the trans smoked. Yes the tech can screw it up if they don't know what they are doing or don't reflash it correctly. I had two processors codes and strategies at one time. Don't know how don't really want to. Reflashed it to the TEC6 and the truck runs ALOT different. I am running some files from all the vendors. Innovatives, DJ's, and Doug's are VERY strong. Shift a little harsh when the TQ locks up but I have the Suncoast in there.
1997 Dodge 2500 CUMMINS 5 spd 4x4, 16* timing, #10 plate, pump mods that make it go real hard, 3gsk, South Bend Con FE, studded and o-ringed, AEM Workhorse intake, Straight 4 inch exhaust into 6" Aussie tip Black powder coated stacks, modified turbo non wastegated now and the two big cowbells are now residing on my Goat. Smokes like a freight train and "Hey I got a goat finally!!!!!"
Now my wife's:2006 F-150 Crewcab XLT 4.6L V8 with every option available.
BigBlue is offline
post #8 of 9 (permalink) Old 08-16-2006, 10:23 PM
jello's Avatar
I'm a tec6 running dougs tunes, runs great.
2003 F-350 King Ranch 6" lift, SCT, MBRP no cat or muff
jello is offline
post #9 of 9 (permalink) Old 09-01-2006, 08:31 AM
All trucks that have 06E17 will need to have the VGT Learn procedure performed. Some technicians forget this last little detail.
maxium4x4 is offline
