04 Edge/Head Problems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_BigPSD, this thread has received 9 replies and been viewed 1017 times.
post #1 of 10 (permalink) Old 09-08-2006, 12:22 AM Thread Starter
Ok here is whats up...
04 dually, edge for 3 months, 4" Exhaust...
Took out the edge 3 months ago after having it in for 3 months(always on 3)...Got the EGR cooler replaced by dealer, having probs with it last week, took it into the dealer and they ripped it apart found warpped heads by .3-4 thousand and the burn pattern on the top of the piston is outside of the cup thing.
What should i do?
-Resuface the heads, new gaskets and hope the bottom end holds up?
-New Heads, Gaskets, and hope the bottom end holds up?
How weak are the bottom ends on these things? Mostly the rings? Can the heads be resurfaced? Will the gaskets hold up .004 of warpage...
PLEASE HELP, DEALER NEED ANSWER TOMORROW!
Thanks:thanks:
imported_BigPSD is offline
post #2 of 10 (permalink) Old 09-09-2006, 06:08 PM
Well a brand new set of heads from ford were showing more than a 4000 of inch off they were not within 1000 of in inch till they came out 8-12-06 they came out with new heads. I have ran the edge on high power for 5000 miles, had the six gun on for 15000 miles and ran it on level 6 on my 04. when they pulled the heads of the pistons have a burning pattern. but there was no cylinder walll scoring so i did not replace the short block. If you have cylinder wall scoring then replace the short block. defently get new heads the updated ones.and due studs while you there
[/B]2004 F-350 Lariat 4x4/CC/SRW/6.0 PSD
18 Inch Suspention with Atlas Springs,Cross Over Sterring With Ram Assist, 6 Chrome 2.5 Kings Piggy Backs, Ladder Bars Front And Rear With,Heims,Custom Cross member,Re-Indexing Ring On Transfer Case,5.13 Yukon Gears, Detroit Locker Front and Rear, High Angle Driveline Long Slip Front Shaft, High Angle Driveline Two Piece CV Rear Shaft, AMP Research Steps, RBP Turbo Back Exhaust With 5 In Tip,AFE Intake, Banks Intercooler,03 Turbo,Heads Ported & Polished By John Wood,ARP Headstuds,EGR Delete,ZEX Nitrious,SCT By John Wood, Mag-Hytec Front & rear Diff Cover, Mag-Hytec Trans Pan ,3 Gauge Pilliar, Dana 80 Rear Axle, 22.5 Super Single Alcoas With 45 Inch Tires, 2008 Front Clip![/B]
2005 F-350 Lariat 4x4/CC/Drw/6.0 psd/4.10 Rears
Airaid Intake,RBP Turbo Back Exhaust,ARP Studs,SCT By John Wood,Banks Intercooler,Edge Juice Platinum Gauges Only,EGR Delete,2.5 DR Levling Kit,On Black KMC Rockstars,Pulls 2006 Cl 4005 Weekend Warrior
GCVW- 33,585 pounds Loaded
pics http://community.webshots.com/user/rbp04
760 PSD is offline
post #3 of 10 (permalink) Old 09-09-2006, 11:40 PM
I believe that this might help. ATS has a set of heads that might help you in your situation. Their heads along with the fire rings are said to eliminate the head gasket problem. They also machine their heads so they might have a cheaper fix than brand new Ford OE heads. Just a thought.
TGentry is offline
post #4 of 10 (permalink) Old 09-10-2006, 12:32 AM
Diesel Pro
if its in warranty just take it back to ford and have them fix it
2006 Dodge 2500 2wd QC SB 5.9 Cummins, 48RE Auto, 4" Exhaust, TS MPD W/HUD, Airaid Intake, 6k HIDs, GoGo Built Tranny, BDTD with Crazy Larry
13.85 @ 99 MPH
BFD99 is offline
post #5 of 10 (permalink) Old 09-10-2006, 03:22 AM Thread Starter
they know its chipped due to the burn pattern on the piston top..."so they say"
post #6 of 10 (permalink) Old 09-10-2006, 10:10 PM
TDG MAFIA MEMBER #44
Send a message via AIM to 6point6 Send a message via MSN to 6point6
yep it makes a star pattern on the piston.
2006 CC FX4 PSD 6.0 (GONE)
2005 LLY Duramax CC SB 4x4 - PPE Hot +2 ET on Level 8, MBRP 4" Straight piped Exhaust, PPE Intake, 315 Cooper STT's on stockers!
6point6 is offline
post #7 of 10 (permalink) Old 09-11-2006, 01:55 AM
BogginF350's Avatar
run it for a couple thousand miles stock, even if its pukin
Josh Davis
6.0L Ford
6.4L Ford
WWW.RIVERCITYDIESEL.COM
(309) 699-2488
BogginF350 is offline
post #8 of 10 (permalink) Old 09-11-2006, 02:10 AM
Suck,Squish,Bang,Blow
StuckinMud's Avatar
Heres my pistons with 20k of the SCT extreme race file. Its driven hard, look at the combustion that past the gaskets!! But also note there is NO star pattern on the pistons.
Name:	DSC00334 (Small).JPG
2004/04 F-350 6.0L(b.o.d. 12-11-03)
Just a couple of Mods :Thumbup:
More toys than time...
StuckinMud is offline
post #9 of 10 (permalink) Old 09-11-2006, 08:51 PM
Is the star pattern something you would expect to see only if you run it really hard?
gopher is offline
post #10 of 10 (permalink) Old 09-11-2006, 09:49 PM
Ub's truck with over 100k on it had no star pattern either. Maybee it has something to due with the edge, and too much timing, or dealer bs.
03six0 is offline
