edge help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by coolinthewoods, this thread has received 3 replies and been viewed 703 times.
post #1 of 4 (permalink) Old 02-24-2007, 08:06 AM Thread Starter
Coolinthewoods
coolinthewoods's Avatar
edge help
I bought a used edge system from a dealer who sells used rigs and said he did not want this on his truck, so a case of beer and I own it The model number is EJF1000. It has a egt probe and a three way togal switch and a green plug for something. I hooked it up and it works great! My question is what are the three postions on the switch. My guess is race eco and tow. Thanks Jesse
2003 F-250 XLT 6.0 POWER STROKEN DIESELAFE intake, 4inch mbrp,no kitten or muff,single 5inch stack,banks high ram intake,EGR DELETE,ARP STUDs,SCT live wire with Erics race tunes.8" rough country lift Proud to be an ALASKAN even though it sucks to order parts and to pay more for shipping then the parts are worth.
coolinthewoods is offline
post #2 of 4 (permalink) Old 02-25-2007, 01:52 PM
mattsn's Avatar
i used to have the EDGE and i think your correct with your suggestions. ( going by memory) You can order the monitor and get all five settings . That green plug is for the Monitor. it shows digitally what most gauges will show depending on the model. Boost, pyro, water, trans , ect.
mattsn is offline
post #3 of 4 (permalink) Old 02-25-2007, 02:23 PM
SLAPS President
teamroper60's Avatar
Images: 9
The settings are 60/80/100hp with the toggle. The 80hp setting is in the middle. You may have to play with it a little to find which side is the 60 and which side is the 100, but once you've tried both you will figure out which one is which pretty quick.... Huge difference between 60hp and 100hp!!
mattsn is correct, the green plug is for the Attitude monitor. If you don't have it, you won't use the green plug, the pyro or the MAP sensor wire.
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #4 of 4 (permalink) Old 02-25-2007, 06:20 PM Thread Starter
Coolinthewoods
thanks guys
