clearing the tuned bit? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by whanner, this thread has received 2 replies and been viewed 525 times.
post #1 of 3 (permalink) Old 05-04-2009, 01:23 AM Thread Starter
whanner's Avatar
anyone know how long it takes for the truck computer to loose the signs of being tuned. I was told it throws the same code as a weak or dead battery whe returned to stock. I need to take the truck back in and do not want it to show any signs of being tuned. Not sure how much memory the truck has.
06' F350
I'm not a Diesel Mechanic or Expert. All posts are just guesstimations.
4" Turbo Back Exhaust, 2" lift in front,1" Lift In the Rear, EGT Gauge, ARP Studs.
whanner is offline
post #2 of 3 (permalink) Old 05-04-2009, 01:45 AM
Sawed Off's Avatar
Theirs some people that try to clear the memory with un hooking the batterys
others try to cycle the key so many times. But I've heard also, it really dosen't matter on
if you do anything because the mechanic can find out if its tuned depending how far they want to get involved on it. Also I've read that the spray pattern on the injectors is different so the detonation points on the piston is also another way to determine if their was anything done to it. I've just read this on sites so its just my 2cents, Hope it helps ya out pal!
2010 6.4 CC
The Diesel Garage
Can You Keep Up
MODS
recon lights
20" predator8 wheels
Toyo AT's
Rip 06 6.0 You were a great truck and will be missed
Sawed Off is offline
post #3 of 3 (permalink) Old 05-04-2009, 04:00 PM
StrokerDude's Avatar
I have seen that difference in the spray pattern, and it is pretty obvious.
Alex C.
StrokerDude is offline
Clearing Codes RevScorpion Medium and Heavy Duty 3 08-27-2010 03:16 PM
DPF'less Tuned 6.4L vs Tuned 6.0L FX4DUDE 2008-2010 6.4L Power Stroke 21 10-13-2007 03:46 AM
Land Clearing equipment??? ACC inc. Utility & Farm Tractors 23 06-02-2007 10:59 AM
clearing 38's tasman650 General Ford Truck and Excursion 10 02-08-2007 06:59 PM
clearing PCM SFD74 2003-2007 6.0L Power Stroke 12 06-19-2006 01:15 AM
