what tuner or chip - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by massa6.0,87, this thread has received 8 replies and been viewed 933 times.
post #1 of 9 (permalink) Old 05-07-2009, 01:23 AM Thread Starter
what tuner or chip
i have a 6.0 power stroke and i want to know what you guys recommend i have been looking at sct. the problem i have right now is what is better i have been looking at sct livewire or x3 or x2? I pull but not a lot. so if you guys can help me out with this. when i had a durmax it was a lot easier to just go with efi.
massa6.0,87 is offline
post #2 of 9 (permalink) Old 05-07-2009, 02:01 AM
I Wanna Go Fast!
brentos's Avatar
sct is the efi for the 6.0 If you want digital gauges get the livewire with egt probe kit. if you want to get analog or no gauges get the x3 or 2. All three do the exact same thing as far as tuning the truck its just the livewire has gauges and the x3 is the new 2 (just back lit screen
brentos is offline
post #3 of 9 (permalink) Old 05-07-2009, 03:04 AM Thread Starter
thanks man so what is the idea with the levels the chip comes with and who do you guys recommend for the costume made files for power?
post #4 of 9 (permalink) Old 05-07-2009, 05:35 AM
********* and Mafia #90
Bcarriveau's Avatar
all depends, i would say a HIGH hp level with stock sticks will get you ~140-150hp, there are a few sct tunes on the board. Its also a programmer not a chip so there is no shift on the fly. Your tranny will thank you for this programmer vs the others..
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #5 of 9 (permalink) Old 05-07-2009, 12:29 PM
You can call me French
6.0turbodiesel03's Avatar
Stick with the SCT and you will be happy. Get some conservative custom tunes for now because I figure you are still on stock head bolts. Also to the Garage.
-French
2003 Ford F-250
6.0L Powerstroke Diesel, CC, SB, 4x4
ZOODAD mod
DIESELS FOR CHRIST
6.0turbodiesel03 is offline
post #6 of 9 (permalink) Old 05-07-2009, 01:31 PM
Another recommnedation here for the sct. Ive had the bansk six gun and the edge juice and attitude. Nothin compares to a custom tuned sct. The tunes are top notch and the transmission tuning is unbelievable. Even the canned tunes that come on the sct x3 are much better than anything else out there for a 6.0
-Caleb
2010 Sterling Gray F-250 FX4 Lariat CC SB 6.4L
4 inch lift, 35 13.50 Cooper stt's on 20x10 Mazzi Hulks
Previous trucks: 02ccsb 7.3, 05ccsb 6.0, 05cc king ranch dually 6.0, 05ccsb king ranch 6.0
nastyp-stroke1288 is offline
post #7 of 9 (permalink) Old 05-08-2009, 02:10 AM Thread Starter
yeah all stock head studs but i hope they go under warrnty but the screen that comes with livewire easy like the edge or should i just use sct x3 with my gauges that i already have. oh yeah what about this dam egr **** should i block it off or leave it alone?
post #8 of 9 (permalink) Old 05-08-2009, 02:13 PM
If you already have gauges then the cheapest and easiest thing to do would just be to go with the x3. The x3 is basically the same thing as the livewire. The livewire just has digital gauges. So if you already have analog your good to go. As far as the egr goes it should be blocked off. But it depends on your warranty situation. Some people dont want to void the warranty so they leave it on. And some states have emissions testing. But its really up to you it depends on your situation as far warranty and location go
-Caleb
post #9 of 9 (permalink) Old 05-08-2009, 05:58 PM
singles member #53
s_bogedain's Avatar
Ya custom tune are the way to go i believe. you can get a good tow tune with EGR and then have a race tune with it shut off that way you can bounce between as your needs change. And like Bill sad your trans will thank you. As a tip when you change tunes drive easy on it for 20 to 30 miles because the trans does go through a relearn process. Have fun!!!
2003 ford f-350 crew cab short bed 4x4 sct, billet grille, clear corners, recon cab and mirror lights, silverstar head and fog lights, bed liner, tonneau cover, tinted windows, double din touch screen dvd player, bully dog RFI intake, no egr, 5" exhaust, 2 10 inch clarion subs, EDGE for monitoring, window vents,
1997 dodge dakota ext short box all i can say is....440 and spray.
1998 ford escort. everyday beater
s_bogedain is offline
best chip/tuner for LB7? HotSauce2138 LB7 Tuner Forum 15 04-08-2008 03:50 AM
best chip/tuner? HD_F250 6.7L Cummins (2007.5-2011) 13 02-12-2008 08:51 PM
? about dp tuner chip imported_fast_and_furious 1994-2003 7.3L Chips & Tuners Forum 12 07-09-2007 01:54 AM
what tuner or chip Robinhood 1994-2003 7.3L Power Stroke 6 06-03-2007 02:07 AM
Chip Vs Tuner wastedwagesracing 2003-2007 6.0L Power Stroke 2 11-30-2005 07:44 PM
