ID aggressive tune, boost level - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by scameron, this thread has received 15 replies and been viewed 1635 times.
post #1 of 16 (permalink) Old 05-23-2009, 04:17 AM Thread Starter
wondering what you guys see on this tune. loaded mine tonight to see if my boost level would change over the street tune. still just over 20psi. i have deleted my EGR. boost level doesn't change from stock to tuned. don't know if this is because i am on stock bolts, maybe leaking boost somewhere, or due to the EGR delete giving me the so called EPA mode.
scameron is offline
post #2 of 16 (permalink) Old 05-23-2009, 04:19 AM Thread Starter
aggressive street tune sorry.
scameron is offline
post #3 of 16 (permalink) Old 05-24-2009, 03:27 PM
I would definately check for a leak somewhere. I've had the boot on the compressor side crack on me before. Although I didnt lose any boost a few people I know have blown them. I have the EGR deleted on my truck and am on stcok tuning at the moment and I can see 30+ in OD with T/C locked up. I'm not sure if you have your EGR valve plugged in or not but I would plug it in if you dont and try it. I read that if thats unplugged it will only boost to 20 or so but I cant speak from experience.
Kiddyextreme is offline
post #4 of 16 (permalink) Old 05-25-2009, 02:17 AM
What year is your truck? Is there still and EGR valve plugged in to make the computer happy? Depending on year and how fully the EGR was deleted it could be the EPA mode.
EPA...
cartmanea is offline
post #5 of 16 (permalink) Old 05-25-2009, 02:00 PM
harry6.0's Avatar
So, the low boost level occured immediately after deleting the egr cooler? If so, I would first re-check to see if something was loose somewhere like a boost tube boot and clamp not sealing good. Under wide open throttle egr is supposed to be shut off anyway, so I would think you would still have normal boost levels if everything else was ok. Are there any codes? If there is, that may explain a no egr flow detected and possibly set it into some type of low boost mode. Are your custom tunes set up for no egr? But like was already mentioned, if your egr valve is unplugged, that maybe the problem. Harry
harry6.0 is offline
post #6 of 16 (permalink) Old 05-25-2009, 07:55 PM Thread Starter
EPA...
yeah cartmanea, i started a thread over on the ford truck forum a while ago about troubleshooting my low boost. i think you mentioned plugging the valve back in. i did and nothing changed. if the EGR valve were dead, would that make a difference. i can't see how seeing that most delete kits you buy completely remove the valve. went through the truck and found the upper IC to be cracked, but i don't think it is leaking. a few others mentioned some things i haven't tried yet. my tunes are from Eric at ID. so yes the EGR is subpose to be shut off. Eric mentioned the boost for the standard street tune would be mid to low 20's. harry6.0 yes immediately after i completely deleted the EGR system, beside the valve, the truck would not boost much over 20. i see 22 at best. yes, had codes for the EGR; something like P0404 & P0405. i will be tearing into the truck here soon so i will try to replace or fix what ever i find.
scameron is offline
post #7 of 16 (permalink) Old 05-26-2009, 09:47 PM
ZIKA's Avatar
High boost!
I got the agressive race tune from them and my boost would hit 34psi with blown head gaskets. I just put studs in it and deleted my egr and it will just hit 35psi and my gaskets were super blown.
ZIKA is offline
post #8 of 16 (permalink) Old 05-26-2009, 11:26 PM
Just a college kid
4x4freak's Avatar
i hit 34 psi in OD
Stolen and rebuilt- 2005 6.0 CC SB 4x4-SCT-ARP-Fass 95/150-O/D Alternator pully-GoGo intake manifold
Special thanks to Doug at GoGoDiesel
4x4freak is offline
post #9 of 16 (permalink) Old 05-27-2009, 02:54 AM Thread Starter
Originally Posted by 4x4freak View Post
i hit 34 psi in OD
yeah that sucks. truck spools great and fast. to be honest the turbo is loud at low rpm. like when i unplugged my EGR to see what would happen way before i deleted it. spools fast to 20 and dead stops. i will have to tear into the damn thing again to see if i have a leak. i really think it is still in some kind of EPA mode, but don't know. going to replace the intake gaskets so i will look everything over, but can't do if for about a month. sucks.
scameron is offline
post #10 of 16 (permalink) Old 05-27-2009, 05:36 PM
05PSD's Avatar
Hey scam, my top boot was torn too but not leaking. This is the second time it was torn.
My truck behaves the same way. EGR unplugged and 20-22lbs boost, plugged in and I get 30. Definately some sort of "default" fueling going on....
05PSD is offline
ID std. street tune boost level scameron 2003-2007 6.0 Tuner Forum 1 05-03-2009 07:34 PM
ID's aggressive street file strokin6L 2003-2007 6.0 Tuner Forum 12 04-20-2009 11:04 PM
Boost level??? cumminsdieselfreak 1994-2003 7.3L Power Stroke 8 03-11-2008 10:34 PM
Safe boost level? Cowboy 24 Valve Performance 9 12-13-2007 01:25 AM
Juice/Attitude on level 2, boost goes way up Country 5.9L Cummins (2003-2007.5) 13 08-12-2006 02:29 AM
