cfm+ largemouth kit - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sjladd6_0L, this thread has received 19 replies and been viewed 1635 times.
post #1 of 20 (permalink) Old 06-05-2009, 02:14 AM Thread Starter
cfm+ largemouth kit
Just got done installing a cfm large mouth intake kit on my 04, 10:06pm. The kit was straight forward to install, i ran the truck for a while and everything seems to be running right. Now i have a question for you all, to install the large mouth kit i had to take off the egr setup that sits under the intake. Should i still do the entire egr delete kit, or run what i have now? any suggestions would be great. I will try to post some pics later this weekend.!!!
sjladd6_0L is offline
post #2 of 20 (permalink) Old 06-05-2009, 02:18 AM
SLAPS President
teamroper60's Avatar
Images: 9
EGR setup under the intake?? You sure you aren't talking about the throttle body (which 04's are the only ones to have had)?? And if you are, then yeah, you should still do the EGR delete...
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
The Following User Says Thank You to teamroper60 For this addition to TDG:
sjladd6_0L (06-07-2009)
post #3 of 20 (permalink) Old 06-05-2009, 02:45 AM
I can count to Potatoe
yeah if you have an 03 or 04 you have a throttle body which never did anything to being with, i guess the plan was to have the parts there and implement it in future generations but was later removed, you will still need to do an EGR delete, which is the long 2x2 like pipe on the passanger side under the intake manifold!
dayusex is offline
The Following User Says Thank You to dayusex For this addition to TDG:
post #4 of 20 (permalink) Old 06-06-2009, 06:38 AM
Lurking
diezel's Avatar
Nice job.... do you have any pic's?
I need to do a intake elbow,just don't know which one...
-Sean-
04, crewcab 6.0 superduty fx4 sport, DR10.5 lift,22" rims,40" TOYO'S,black on black,AFE II si intake,MBRP 4" exhaust, no cat,no muff,ORU traction bars,ORU hydro assist,4.56 gears,ARB rear locker,power locker up front for snow driving,MAG HY-TEC diff and trans covers,velvet ride shackles,SCT by innovative ,GROVER train horns with 1/2" line's ,7 gallon onboard air set up with quick connect,AUTOMETER gauge's,McCulloch HID's 6000K,ARP studs,coolant filter....
EGR delete and Trusted performance oil/fuel delete,crossover fuel lines with fixed orifice,spearco intercooler,banks cac tubes,cfm big mouth and Airdog II,with custom ss braided kevlar hose from tank to heads....
FICM 58 volts from SWAMPS,moderate flash by ID....
built by diezel, (except gears by chris at ORU)
Riding High Club #33
Singles Club #239
Ridin' Dirty Club #48
American Club #37
Bomb Squad #36
diezel is offline
post #5 of 20 (permalink) Old 06-06-2009, 01:49 PM
i would go with the largemouth, mostly becuase you get 3 ports, a new pipe, and 2 new boots that are WAAAAy better than OEM quality. I never thought I would need three ports, becuase I just wanted a boost gage but now that im thinking abotu doing nitrous im very happy!
dayusex is offline
post #6 of 20 (permalink) Old 06-06-2009, 03:27 PM
Lurking
diezel's Avatar
Sounds good...and Nitros is always fun
Did you throw a code after removing the butterfly valve?
Mines an 04 also....
-Sean-
Singles Club #239
American Club #37
Bomb Squad #36
diezel is offline
post #7 of 20 (permalink) Old 06-06-2009, 06:27 PM
i didnt throw a code and i have an 03, you should be in the clear!
dayusex is offline
post #8 of 20 (permalink) Old 06-07-2009, 01:24 PM
strokin6L's Avatar
I have the cfm+ large mouth kit and have been running it for a while now. Deleting the throttle body plate will not throw a CEL...you'll be fine.
strokin6L is offline
post #9 of 20 (permalink) Old 06-07-2009, 05:15 PM Thread Starter
i was have asleep when i wrote that- i took the throttle body off. So now the plan is an egr delet. Any kit out there that would be the best buy?.......................pics coming soon!!
post #10 of 20 (permalink) Old 06-07-2009, 08:58 PM
I Wanna Go Fast!
brentos's Avatar
i like the kit from RCD but dfuser sells some to
brentos is offline
