x2 vs. x3, need help guys - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by toshmago, this thread has received 10 replies and been viewed 1179 times.
post #1 of 11 (permalink) Old 06-14-2009, 06:32 AM Thread Starter
toshmago's Avatar
I found a x2 for $100, seller says it's unlocked ready to go. Should i buy it? can i put custom tunes on it? will it work as good as a x3? any input would be appreciated. thanks.
2006 F-250 XLT FX4 4X4 SuperCrew. Bone Stock(so far)
toshmago is offline
post #2 of 11 (permalink) Old 06-14-2009, 06:36 AM
SLAPS President
teamroper60's Avatar
Images: 9
I can't really give you an answer as to how the X2 and X3 compare to each other since I only have the X2 but yes, you can put custom tunes on the X2...
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #3 of 11 (permalink) Old 06-14-2009, 06:38 AM Thread Starter
toshmago's Avatar
How many does it hold? can you adjust tires and speed limiter and such?
toshmago is offline
post #4 of 11 (permalink) Old 06-14-2009, 07:05 AM
SLAPS President
Images: 9
It holds 3 tunes. Yes, you can adjust those things, along with gear ratios.
#43
The Following User Says Thank You to teamroper60 For this addition to TDG:
toshmago (06-14-2009)
post #5 of 11 (permalink) Old 06-14-2009, 11:54 AM
UpstateDieselGuy's Avatar
I agree. In fact, I think the old X2 is a great unit that doesn't seem to have some of the quirks that the newer devises have. Chris
SOLD
UpstateDieselGuy is offline
post #6 of 11 (permalink) Old 06-14-2009, 12:56 PM
Sader's Avatar
Talking
I have an X3 and have zero issues. If I remember what I was told the X2 and X3 are similar but the time to load a tune is somewhat faster on the X3.
For the price I'd snatch the X2.
2016 F350 C/C, S/B, FX4, PSD, T/S, Loaded Lariat, best PSD yet !
2005 F250 C/C, S/B, FX4, PSD, T/S, Loaded Lariat, Love my 6.0...............movin' on up
2004 F250 S/C, L/B, 4x4, PSD, T/S, XLT - Great Truck traded on the 05
2000 Excursion Limited, PSD, 4x4, Stock, sadly it's gone...
1991 F250 Reg. Cab L/B, 4x4, 7.3L diesel, E4OD, Lariat ran the wheels off
" We may or may not worship God, but John Moses Browning made sure we can choose "
"Security without Liberty is called prison"
― Benjamin Franklin ―
Sader is offline
post #7 of 11 (permalink) Old 06-15-2009, 03:56 AM
StrokerDude's Avatar
X2 only holds 3 tunes total... Doesn't the X3 hold three custom and three canned tunes?
BTW, my X2 loads a lot faster than a friends Livewire does.
Alex C.
StrokerDude is offline
post #8 of 11 (permalink) Old 06-16-2009, 02:59 AM
Sader's Avatar
The X3 is similar to the X2, the Livewire is adifferent animal.
Sader is offline
post #9 of 11 (permalink) Old 06-16-2009, 02:44 PM
The X2 works just fine... If you need to just store more tunes on your computer so you have more than just three, then load different combos on the tuner and your good to go.. No need to spend a bunch more money IMO...
'03 F250 CCSB SRW, SCT, K&N, MBRP STRAIGHT PIPED, SNOW STG 3, LIFTED 6" ON 37'S, RCD's EGR DELETE, AP HD200, TP STG 1 FUEL SYSTEM, HYPERMAX STG 1 INJECTORS, ARP'S, ID TUNED, VARIOUS LITTLE GOODIES...
R33615 is offline
post #10 of 11 (permalink) Old 06-18-2009, 12:35 AM
The X3 holds stock and 3 canned tunes and 3 custom tunes plus you can make adjustments. The X3 has more memory so it loads a lot faster. I dont know if the X3 is worth $300 more then the X2 that you have though.
heavyhaller is offline
Little help guys... Rosco 2003-2007 6.0L Power Stroke 3 02-10-2009 08:46 PM
need help guys! imported_7inchstack 5.9L Cummins 12 Valve (1994-1998.5) 7 04-28-2008 03:19 AM
Need your guys help again please. BlackSuperStroker33 2003-2007 6.0L Power Stroke 2 02-04-2006 12:24 AM
