03 6.0 SCT question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Hybrid_4x4_Superduty, this thread has received 12 replies and been viewed 1016 times.
post #1 of 13 (permalink) Old 06-17-2009, 06:50 PM Thread Starter
TDG Mafia Member #64!
Hybrid_4x4_Superduty's Avatar
Send a message via Yahoo to Hybrid_4x4_Superduty
03 6.0 SCT question
I have a sct xcal 3 from dj with his looney. My question is after i run my truck wide open for anything over about 10seconds when i let off and try to get back on throttle my truck feels is if i only have half throttle until i stop my truck and restart it (275hp appx on dyno.. tried it). The truck seems to miss a bit over 3,000rpms slightly. It only put down 407hp on the dyno and i figured it would put down more than that with intake and stacks. Im thinking my tune needs ajusting or something? Djs not in business anymore and i was wondering what i should do or what my problem seems to be? thanks, adam.
-ADAM-
2008 Ford F-350 King Ranch, 4x4, 6.4L, Powerstroke Diesel, Torqueshift, Spartan Tuned, 4in FloPro Straight Duals, Afe Stg 2 Intake, Chromed & Tinted out!!! 115k Miles!
Hybrid_4x4_Superduty is offline
post #2 of 13 (permalink) Old 06-17-2009, 07:16 PM
DJ is still around but only serving his previous customers. e-mail Mama Benz with your conserns.
heavyhaller is offline
post #3 of 13 (permalink) Old 06-17-2009, 09:59 PM
Powerstroke Puller
6.0superduty's Avatar
Is that the only tune you have? Try it with a different tune or back to stock and see if it still does the same thing. That will tell you if its in the tuning or not.
07 Classic LBZ 4x4
Efi
leveled out
Suncoast stage 4 w/ 1056
22" Fuel wheels
04 6.0 CC SRW (Sold)
Some pullin goodies
B & B Pulling Team
Troyers Diesel Performance
6.0superduty is offline
post #4 of 13 (permalink) Old 06-18-2009, 12:00 AM
I Wanna Go Fast!
brentos's Avatar
i take it, it smokes when its doggie and gets hot. sounds to me like stuck turbo veins that is what mine did when mine were coaked up.
brentos is offline
post #5 of 13 (permalink) Old 06-18-2009, 08:23 AM
is could be the turbo veins, but do you have upgraded injectors? upgraded fuel system? you could be running out of fuel on the high end and thats why you dyno'd lower than expected
DunesRunner08 is offline
post #6 of 13 (permalink) Old 06-18-2009, 05:01 PM Thread Starter
My turbo is working fine, the veins cycle up and down at an idle. Plus i have a boost pressure guage and its operating good. Stock it runs good and smooth. I will see if i can find vivs email, thanks!
-ADAM-
post #7 of 13 (permalink) Old 06-18-2009, 05:06 PM Thread Starter
Stock fuel system, it still has a slight haze of black out the stacks on high rpm but it aint much, my dads looney definitly smokes more and his is an 05 with stock fuel system.
-ADAM-
post #8 of 13 (permalink) Old 06-18-2009, 05:06 PM
lilpooh's Avatar
I had the same issue with all of my looney tunes from DJ,it would go into limp mode after being at wot,I was told it was a safety setting put in the tunes, If anybody can clairify on this please let me know, but that was what I was told, or if DJ can fix this I'll give them a call.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #9 of 13 (permalink) Old 06-18-2009, 05:58 PM Thread Starter
seems to be what mines doing. or if im wide open and dont let off around 110 it stops pulling and seems to go into limp. thats definitly not right, ive had this truck doing 137mph b4
-ADAM-
post #10 of 13 (permalink) Old 06-26-2009, 05:58 PM Thread Starter
I sent vivan an email about a week ago and havent gotten a reply, does she have a new eMail or something?
-ADAM-
Turbo Question(Tech Question) Liftedpsd 2003-2007 6.0L Power Stroke 7 09-16-2007 03:35 PM
Boost question, maybe MAP sensor question 6_Myles 1994-2003 7.3L Power Stroke 5 10-28-2006 12:42 AM
Edge Juice Question Question Jaadc01 General Ford Truck and Excursion 6 05-23-2006 12:40 PM
