FICM and X-race tunning - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 6.0turbodiesel03, this thread has received 24 replies and been viewed 2498 times.
post #1 of 25 (permalink) Old 06-30-2009, 05:26 PM Thread Starter
You can call me French
6.0turbodiesel03's Avatar
I am currently running Cale's 140 tune but want to get my FICM tuned. I have been told by a couple of people that Cale's tunning and Innovatives FICM tunning won't work well together and that for the best results, I should run ID's tunning all around.
What can I expect if I run ID's FICM tunning and get their X-race tune as well? Just trying to get those who have this done to their trucks opinions.
Thank you,
French
2003 Ford F-250
6.0L Powerstroke Diesel, CC, SB, 4x4
ZOODAD mod
DIESELS FOR CHRIST
6.0turbodiesel03 is offline
post #2 of 25 (permalink) Old 06-30-2009, 06:18 PM
If its a daily driver you might be better off with X-Street. Almost the same HP, but the TC locks up less. X-Street with FICM tuning will probably blow Cale's 140hp out of the water.
cartmanea is offline
The Following User Says Thank You to cartmanea For this addition to TDG:
6.0turbodiesel03 (06-30-2009)
post #3 of 25 (permalink) Old 06-30-2009, 07:08 PM Thread Starter
This isn't my daily driver anymore, although I still drive it quite a bit on weekends. I may end up getting both tunes.
-French
2003 Ford F-250
ZOODAD mod
DIESELS FOR CHRIST
post #4 of 25 (permalink) Old 06-30-2009, 07:32 PM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
I'm interested,....because I have yet to see ANY changes in track times or dyno numbers in just a FICM tune...
The people I've heard from say "butt dyno" maybe a little difference,...but none of them have seen a track or Dyno increases.
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
The Following User Says Thank You to TANK'S 250 For this addition to TDG:
6.0turbodiesel03 (07-02-2009)
post #5 of 25 (permalink) Old 07-01-2009, 03:00 AM
I Wanna Go Fast!
brentos's Avatar
And the hole crack about blowing cales tune out of the water is probably a line of BS because cale has a dyno and if it adds a true 140 then a 20 horse (mabey) bumb is not that much more. and yea the ficm tuning....i have yet to see a increase from anyone.
brentos is offline
post #6 of 25 (permalink) Old 07-01-2009, 11:25 AM
Pursuit Interceptor
HeavyAssault's Avatar
Images: 5
Okay...who has a reputable dyno on the East Coast? Close to VA is best...
HeavyAssault is offline
post #7 of 25 (permalink) Old 07-02-2009, 01:40 AM
ebusa's Avatar
xstreet without FICM will blow Cale's 140hp out of the water! LMAO, I've ran both.
-Evan
2005 F350 Crew Cab LB FX4 Lariat
Loaded-Leather, Sunroof, Chrome Mirrors,Tow hooks
5'' Tuff Country Lift
Toyo 35'' MT's on Race Line Renegade 20's
ARP Studs, EGR Cooler Delete, Coolant Filter
AFE Magnum Force Stage II CAI
MBRP 4'' Exhaust Turbo back, No Cat
SCT X3 Tunes -Strat: VXCF9
Powemax Turbo
PHP FICM tuner
ebusa is offline
post #8 of 25 (permalink) Old 07-03-2009, 02:49 AM
strokin6L's Avatar
I've got ID's FICM tuning and run the x-race as a daily driver. Truck runs great. I would definitly get the FICM tuning...it made a huge difference in throttle response alone. There's a guy in my area who has ID's FICM tuning running a superchips programmer and he felt/noticed a seat of the pants difference in power from this. I almost thought redneck6.0L had before and after hp#'s or track times when he got his race tuned FICM from ID, but i could be wrong. I believe the mild version is said to be 30hp and the race version(200cc injectors or higher) was at least 70hp more. The best thing i like about it is the throttle response...that alone was well worth doing it.
strokin6L is offline
post #9 of 25 (permalink) Old 07-03-2009, 02:51 AM
strokin6L's Avatar
Well, your best bet if you get ID's tuned FICM have it dynoed there....Eric is in Elkton, Maryland and has a dyno at his shop.
post #10 of 25 (permalink) Old 07-03-2009, 03:20 AM
TANK'S 250's Avatar
Images: 38
Danny (Imelmo) had his FICM flashed,..took it to the track...no change..
I have considered it,...but it's not worth the money if it's not really doing anything.
Special thanks to:
KLMperformance.com
Black Ops Bumpers
'06 ficm EB.Bldr Whats Been Sold 3 05-27-2009 07:39 PM
6.0L EGR/COOLER/STUDS/SCT/CUSTOM Tunning Package dfuser Supporting Vendors Forum 0 05-14-2009 12:44 AM
Tunning Trans Shift Points??? BUFF_dragon 5.9L Cummins (2003-2007.5) 2 03-16-2007 08:09 PM
Pcm, Tcm, Ficm MOMBENZ 2003-2007 6.0L Power Stroke 0 09-21-2006 01:20 PM
twin turbo tunning redneck6.0l Supporting Vendors Forum 1 05-23-2006 05:57 PM
