SCT Revs for 33" tires - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Eazydeezy, this thread has received 11 replies and been viewed 1108 times.
post #1 of 12 (permalink) Old 06-30-2009, 08:21 PM Thread Starter
Let it all Ride
Eazydeezy's Avatar
Like it says, do any of you guys know what my revs need to be set at for running 33" tires. I recently got new tires and my speedo is jacked because the pragrammar is set for 35's. I tried calling innovative but there out of the office till next week. Thanks for the help guys!
Dominic
Eazydeezy is offline
post #2 of 12 (permalink) Old 06-30-2009, 09:53 PM
lilpooh's Avatar
Several ways, look in the sticky section in this tuner forum. The stickys also show you how to save stock files to pc and has other useful info.
2004 F350 CC DRW King Ranch
lilpooh is offline
Eazydeezy (07-01-2009)
post #3 of 12 (permalink) Old 06-30-2009, 11:23 PM
Banned
wastedwagesracing is offline
The Following User Says Thank You to wastedwagesracing For this addition to TDG:
post #4 of 12 (permalink) Old 07-01-2009, 12:07 AM
UpstateDieselGuy's Avatar
Just keep in mind that SCT does not correct the speedometer, just adjusts for shifting purposes. Chris
SOLD
UpstateDieselGuy is offline
The Following User Says Thank You to UpstateDieselGuy For this addition to TDG:
post #5 of 12 (permalink) Old 07-01-2009, 02:28 AM
I Wanna Go Fast!
brentos's Avatar
should be around 610 RPM
brentos is offline
The Following User Says Thank You to brentos For this addition to TDG:
post #6 of 12 (permalink) Old 07-01-2009, 02:31 AM Thread Starter
Let it all Ride
Eazydeezy's Avatar
Thanks for the help guys!!
Dominic
post #7 of 12 (permalink) Old 07-01-2009, 02:53 AM
strokin6L's Avatar
the last set of 33's i had where around 640 revs, i haven't checked my new set yet.
strokin6L is offline
post #8 of 12 (permalink) Old 07-02-2009, 12:05 AM
610 is what I use for 35s. I verified this with both the rolling tape measure test and my GPS/RPM test. 33s should be closer to 645.
cartmanea is offline
post #9 of 12 (permalink) Old 07-02-2009, 01:30 AM
ebusa's Avatar
610 seems high for 35's!
I'm running my 35x12.50x20 at 595. Got my number by also doing the rolling tape measure. I do have 20'' rims however and M/T tread, not sure if that makes much of a differnce.
-Evan
2005 F350 Crew Cab LB FX4 Lariat
Loaded-Leather, Sunroof, Chrome Mirrors,Tow hooks
5'' Tuff Country Lift
Toyo 35'' MT's on Race Line Renegade 20's
ARP Studs, EGR Cooler Delete, Coolant Filter
AFE Magnum Force Stage II CAI
MBRP 4'' Exhaust Turbo back, No Cat
SCT X3 Tunes -Strat: VXCF9
Powemax Turbo
PHP FICM tuner
ebusa is offline
post #10 of 12 (permalink) Old 07-02-2009, 01:36 AM
Rim size doesn't make a difference, just different tire brands and mine are at about 50-60% treat. One revolution was 104 and 3/8", which works out to 607. I run 610 rather than 605 because as the tread wears it will get closer to 610.
Need bellhousing for NV5600 & 37-39" 20" tires ash_flat_diesel Whats Been Sold 0 04-17-2008 12:10 PM
Pics of 6.5" lift and 35" tires Rwhat General Ford Truck and Excursion 14 04-01-2008 12:31 AM
Anyone running "D" rated tires? Rww General Ford Truck and Excursion 10 07-17-2007 11:41 PM
NBA Headlines Ford: A new No. 1 contender<img src="http://espn.go.com/i/in.gif" width="11" height="11" hspace=4 border="0" alt="Insider"> RSS Feeder The Parking Lot 0 06-09-2006 07:00 AM
stock 18's, 25" tires and a 6" lift... 2008TTCC 2003-2007 6.0L Power Stroke 2 01-03-2006 02:53 AM
