Fuel mileage and towing - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jdydiesel, this thread has received 20 replies and been viewed 2444 times.
post #1 of 21 (permalink) Old 07-10-2009, 09:45 PM Thread Starter
Dually Club #3
jdydiesel's Avatar
So I just got back from running a 700 mile round trip to my dads last weekend. I pull a 33' travel trailer that weighs about 9K. In the past when running just my Banks PowerPDA, i would set it on 4 and get about 13 mpg. This was my first time running the SCT tuner pulling the trailer. I ran Dfusers tow tune with brake, I ran the heavy tow with brake and the aggresive tow with brake from spartan and all three gave me horrible fuel mileage, 10 or less. So my question is why do the SCT tunes give me less mileage? Is it the brake function or the actual engine parameters? I was very tempted to go back to a trans only tune and turn the PDA back to 4.
What are you guys running and what kind of mileage numbers so you get?
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
post #2 of 21 (permalink) Old 07-10-2009, 10:13 PM
lilpooh's Avatar
I've got a 25' 5th wh. About 7000#, towing with DJ's tow tune,no jake, I get 15.xx hand calc. With stock tires and 4.10 gears, never tried my tow w/jake. The truck weighs 8240#,full tank,with me in.
2004 F350 CC DRW King Ranch
lilpooh is offline
jdydiesel (07-11-2009)
post #3 of 21 (permalink) Old 07-11-2009, 12:30 AM
whanner's Avatar
our 5th wheel weighs about 12k plus and get about 11mpg with the free tunes from spartan....heavy tow with engine brake. we have 28k miles on the truck now.
06' F350
I'm not a Diesel Mechanic or Expert. All posts are just guesstimations.
4" Turbo Back Exhaust, 2" lift in front,1" Lift In the Rear, EGT Gauge, ARP Studs.
whanner is offline
The Following User Says Thank You to whanner For this addition to TDG:
post #4 of 21 (permalink) Old 07-11-2009, 03:44 AM Thread Starter
Dually Club #3
jdydiesel's Avatar
I am wondering if the brake feature hurts the fuel mileage?
Jason
post #5 of 21 (permalink) Old 07-11-2009, 03:32 PM
********* and Mafia #90
Bcarriveau's Avatar
thats what im thinking. i ran to IN and back with over 7000K lbs behind me and only got 11 at best. good buy jake tunes
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #6 of 21 (permalink) Old 07-15-2009, 04:06 AM
I pulled my 5th wheel about 400 mile round trip over the fourth and I only averaged about 7 that was with no tune.
2004 Crew Cab Short box 35X12.5X20 Toyo MT's 20X10 Ultra's Edge EVO CTS Airraid Intake w Zoodad mod 4" TB no Cat Mishimoto intercooler egr valve blocked
Soon going to have PHP FICM, ECM, Tuning
Singles # 157
T.D.G. B.O.M.B. # 40
smokeem is offline
post #7 of 21 (permalink) Old 07-15-2009, 10:35 PM
Bcarriveau's Avatar
how much did it weight?
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #8 of 21 (permalink) Old 07-15-2009, 11:39 PM
it grosses 13K also the fan never wanted to shut off. it would turn off then turn right back on. The gauge never ever move from where it normally was. I'm also at 4500 feet and run 35's
Singles # 157
smokeem is offline
post #9 of 21 (permalink) Old 07-16-2009, 12:17 AM
Wind resistance is pretty severe with a travel trailer, especially a tall one/toy hauler. A 5th wheel uses the truck for some aerodynamics and they tend to get better economy. Your tire sizes and gear play a big role too. 4:10s will get better towing mileage than 3:73s.
If you pulled the same trailer with the banks and the sct gave worse mileage, I would be really concerned with the advanced timing the banks pda is doing on you. 4 mpg seems like a big difference. I doubt the engine would last long if the timing is that much better.
My $.02. BTW, my 3:73s with 18" tires gets me 9-10 mpg with my tall 30' toy hauler empty or loaded. Stock or with a tow safe tune (turbo brake enabled) same poor mileage.
2005-6L/PSD F-250 Lariat CC/SB/4x4:
- MBRP 4" turbo back, Dieselsite coolant bypass filter, Frantz oil bypass filter, X-monitor, Fluidampr, fuel x-over line, intake elbow, EGR cooler delete, wrapped headers and turbo, ARP studs, OEM gaskets, ported heads and manifolds to match, Hot FICM w/ ID Flash, 08+ tranny pan/filter.
pstrang is offline
post #10 of 21 (permalink) Old 07-16-2009, 01:46 AM Thread Starter
Dually Club #3
jdydiesel's Avatar
I am running 4:30s. Forgive my ignorance but why would better fuel mileage mean that I was running more timing and why would that make my engine life shorter?
Jason
Towing with 75 hp tune - update with mileage My427stang 2008-2010 6.4L Engine Tuner Forum 5 01-04-2009 10:46 PM
Buddies bad mileage towing HD_F250 2003-2007 6.0L Power Stroke 18 02-12-2008 01:50 AM
Mods For Mileage And Towing HumminsCummins 5.9L Cummins (2003-2007.5) 10 02-06-2008 05:19 PM
Towing mileage? Canyon JYD 5.9L Cummins (1998.5-2002) 10 11-25-2007 06:07 PM
6.4/6.0/7.3 towing mileage Boulder GT3 2008-2010 6.4L Power Stroke 20 04-10-2007 01:22 AM
