Boost on extreme settings??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jrmmustang, this thread has received 3 replies and been viewed 556 times.
post #1 of 4 (permalink) Old 07-15-2009, 02:37 AM Thread Starter
jrmmustang's Avatar
I have erics extreme race and street tunes on my truck and it seems like I can only get 22-24 psi out of them. Does not really smoke at wot only a slight haze on extreme. My EGT's climb fast on the X-street tune It will hit 1600 fairly quick so I think I might not be getting enough Air. I checked my gauge with the scanner on the sct and it is seeing the same thing is my turbo stuck or should I look else where.
New horse
2003 F-350 Crew Dually 4x4 Auto Cold air intake Silverline stainless 4" turbo back SCT erics x-race,x-street, tow
195k runs good
359.8 hp 6-13-09
14.9-91 mph 7-10-09
SOLD IN ITS PRIME LIVE LONG
1995 CC F-350 292,456 miles auto 4x4 4.10 gears
Intake 4" exhaust 160 cc injectors gauges IDM mod ts redone by "TW" 6 pos
jrmmustang is offline
post #2 of 4 (permalink) Old 07-15-2009, 04:05 PM
That boost sounds about right for Erics tunes...Also, I know my EGT's get up there pretty quick and level off. If your seeing sticking, you would notice it off the line more than up top at WOT since I think they usually stick open.
2006 F-250 Lariat CC/SB 6.0 Auto
MBRB Straight Piped|SCT - Went Looney, then Extreme|Accufab elbow|VGT-40 Turbo
8" Fabtech 4-link|Fox Shocks|20 x 10 KMC Diesels|37 x 13.50 Khumo
DiProcol Black Face Boost, Trans Temp, EGT, Fuel Pressure Gauges
FaSSt9602 is offline
post #3 of 4 (permalink) Old 07-16-2009, 09:45 PM
05harley_6.0's Avatar
Im pretty sure your boost is too low
2011 F250 Lariat 4x4 CC SB
Platinum White
6.7 PSD
05harley_6.0 is offline
post #4 of 4 (permalink) Old 07-17-2009, 03:54 PM
Maybe a couple pounds, but mine hovers around 25-27 WOT, if I load the engine from a roll I can peg the 35lb gauge. Wouldn't hurt to check for boost leaks just to be sure...
If you are only hazing at WOT with stock sticks, then you are getting plenty of air.
dashdaq settings sirkdev 2008-2010 6.4L Engine Tuner Forum 2 03-14-2009 10:54 PM
Settings? BigRed6.7CTD 6.7L Cummins (2007.5-2011) 12 02-25-2009 04:05 AM
ppe settings! 1bAdmAx LB7 Tuner Forum 7 02-11-2009 10:52 AM
SCT WOT settings drservo 2008-2010 6.4L Engine Tuner Forum 2 01-16-2009 11:21 AM
EGT and MAX BOOST settings for Edge on a stock truck what does Dodge recomend? griz81 5.9L Cummins (2003-2007.5) 5 04-16-2007 06:43 AM
