Tunes before and after!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by PiRiPi, this thread has received 25 replies and been viewed 2369 times.
post #1 of 26 (permalink) Old 07-18-2009, 04:36 AM Thread Starter
PiRiPi's Avatar
Send a message via AIM to PiRiPi
when u got from stock to a xtreme tune its a huge difference , but after a while the tune feels like it looses power or thats just the driver getting use to the power???
maybe some of us feel this way
6.0L2005 2wd crew cab,afe intake,5" exhaust,coolant filter,high idle mod,EGR delete,APR studs,Harley lights and Grill,6000k hids,fomoto drain valve,60gal rds tool tank,egt,pyro,trans isspro gauge 2" leveling front,moog ball joints, rancho 5000's, & TUNES BY
Innovative Diesel
Soon-Air dog 2, 155 rcd injectors, vgt-ss Stage I
PiRiPi is offline
post #2 of 26 (permalink) Old 07-18-2009, 05:45 AM
lilpooh's Avatar
I had that same feeling back in april 2009 thru may 2009,so on my way home from a canada fishing trip,when I would stop to refuel,it would crank real long several times to get started.took it to the garage,it was the hpop going bad.after it was replaced,it was like driving a new truck again.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #3 of 26 (permalink) Old 07-18-2009, 06:21 AM Thread Starter
PiRiPi's Avatar
it feels like it looses power after a while
Innovative Diesel
PiRiPi is offline
post #4 of 26 (permalink) Old 07-18-2009, 11:22 AM Thread Starter
PiRiPi's Avatar
can i check my icp or hpop pressure with my x3 sct tuner????
im trying to figure out if my hpop is bad, or loosing pressure..
whats the pressure for a hpop 6.0 @ idle
whats the pressure for a hpop 6.0 @ wot
Innovative Diesel
PiRiPi is offline
post #5 of 26 (permalink) Old 07-18-2009, 02:01 PM
********* and Mafia #90
Bcarriveau's Avatar
625psi and probably around at wot.4000 psi.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #6 of 26 (permalink) Old 07-18-2009, 03:39 PM
Superstroker's Avatar
I am having the same problem.. My motor cranks for a while and barley starts and sounds bad for a split second like it might want to die, but it starts.. it does it after it sits for a few and I try to start it.
I think I am going to have my HPOP looked at also, anyone else think this is the problem?
Matt
1999 24v ext cab quad cab long bed Laramie 4x4 : 155k miles, straight piped, Edge Juice w/ Attitude, "Dr Evil" trans rated for 800hp with 2500 stall gear driven TC, airdog 100, 2" leveling kit 33" mastercrafts.
Avatar is before I bought it of course. new pic coming soon
SOLD: 2006 F250 6.0 EXT CAB SBSCT by DFUSER,INNOVATIVE,: 2003 turbo :4inch cool duals and 6inch tips: HP Intake elbow: ARP STUDS: Diprocol Boost, Pyro, Trans, Fuel Pressure guage in quad pod: Isspro EOT guage in dash bezel: HID 6000k Headlights:305/40r22 on ProComp Extreme black and aluminum wheels: 2008 Mirrors,Tailgate, taillights and bumper: Sir Michaels Roll Pan: Billet fuel and Oil Caps:Billet grille: Billet tow hooks:Kenwood Double Din: Acetoned badges:
Superstroker is offline
post #7 of 26 (permalink) Old 07-18-2009, 05:36 PM
lilpooh's Avatar
Matt
It could also be one or more bad injector,dirty filters,one of the sensors,ect you might want to do a search in the fourms to get a idea what might be going on.
lilpooh is offline
post #8 of 26 (permalink) Old 07-18-2009, 05:38 PM
Bcarriveau's Avatar
Matt
that sounds like you may/could have a small Leak in your HPOP system somewhere.. seeing you have a 05+ have you ever upgraded the STC fitting on the HPOP? http://www.forddoctorsdts.com/articl...icle-07-08.php
you would have to check icp pressure wile cranking. the sct will not allow you to watch pressure when cranking.
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #9 of 26 (permalink) Old 07-18-2009, 06:00 PM Thread Starter
PiRiPi's Avatar
i had the same problem it would start when it was cold and when it was warm it wouldnt start because cold oil is more dense and warm oil is less dense cost me about 700 bucks to fix the little fitting
Innovative Diesel
PiRiPi is offline
post #10 of 26 (permalink) Old 07-18-2009, 06:01 PM Thread Starter
PiRiPi's Avatar
how would i go about checking it in my x3 sct??
Innovative Diesel
PiRiPi is offline
tunes imported_newtodiesel 2003-2007 6.0 Tuner Forum 4 03-28-2008 12:59 AM
need sct tunes stacks Supporting Vendors Forum 0 03-09-2008 08:55 PM
sCT tunes keith o 2003-2007 6.0 Tuner Forum 6 02-17-2008 05:05 AM
DJ tunes barry1me 2003-2007 6.0 Tuner Forum 14 06-22-2007 04:54 PM
SCT Tunes Matty69 1994-2003 7.3L Power Stroke 4 04-13-2006 12:48 PM
