sct program question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by droolinforparts, this thread has received 8 replies and been viewed 680 times.
post #1 of 9 (permalink) Old 07-23-2009, 09:27 PM Thread Starter
droolinforparts's Avatar
Send a message via AIM to droolinforparts
how much safer of a tuner is the sct over my hypertech power programer 3 because i am assuming i just popped my head gasgets or cracked heads again and i want a tuner because the truck is a dog with out it but i dont want to deal with this again
'03 F250 XL 6.0LK&N intake, mbrp 5" stacks, SCT X3 with tunes from innovative, 6" superlift, 315-75r-16,boost, pyro, fuel pressure, oil pressure gauges all in the a-pillar,h-11 studs, short throw shifter,fass 95/150 with complete custom fuel lines, south bend clutch, traction bars
Singles #118
B.O.M.B Squad #28
droolinforparts is offline
post #2 of 9 (permalink) Old 07-23-2009, 09:33 PM
skrub67's Avatar
I have been told by many folks that the SCT is safer because of the way the defueling in programmed in to the tune that helps to prevent too much boost/pressure. Not saying it IS better, just going off what I have been told.
Hope this helps.. I'm sure if you haven't already tried the search option you could find way more info from folks that know a lot more than me.. or hopefully they will chime in and help ya out.
skrub67 is offline
post #3 of 9 (permalink) Old 07-24-2009, 12:34 AM
lilpooh's Avatar
When you had your studs done the first time, were the heads and deck checked to see if they were warped or cracked?if they were not warped or cracked the first time who's to say that they didn't crack after studs. Just because they are studded, don't mean that they can't crack.
2004 F350 CC DRW King Ranch
lilpooh is offline
post #4 of 9 (permalink) Old 07-24-2009, 12:38 AM
********* and Mafia #90
Bcarriveau's Avatar
or flat.. SCT is safe when you run it safe. a race tune is not safe IMO. But will save you tranny over the Hyper. SCT is a great thing on the 6L
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #5 of 9 (permalink) Old 07-24-2009, 02:46 AM Thread Starter
well i dont have to worry about the tranny cuz its a manuel and the heads were brand new from ford but i didnt get the block checked
Singles #118
B.O.M.B Squad #28
post #6 of 9 (permalink) Old 07-24-2009, 02:55 AM
I Wanna Go Fast!
brentos's Avatar
i bet the sct will make way more power
brentos is offline
post #7 of 9 (permalink) Old 07-24-2009, 03:05 AM Thread Starter
yea im sure it will but all im really worryed about now is keeping the heads from popping again but having a truck that isnt a dog cuz i am 99.9% sure that the gaskets are good cuz a comp test came back good but i am burning coolant and last time both heads were cracked inside the valve seat
Singles #118
B.O.M.B Squad #28
post #8 of 9 (permalink) Old 07-24-2009, 03:11 AM
I Wanna Go Fast!
brentos's Avatar
probably running too much timing. I havent puked a drop with my current setup but both heads were cracked when i tore it down. This I believe was do to running too much timing with tunes from a sct dealer pm me if your curious to who it was.
brentos is offline
post #9 of 9 (permalink) Old 07-24-2009, 03:17 AM Thread Starter
yea when i had the tuner in i could run that as hard as i wanted and i never got it to de-fuel
Singles #118
B.O.M.B Squad #28
SCT tow program bsexton 2008-2010 6.4L Engine Tuner Forum 2 01-28-2009 02:26 PM
program question drummerboydw 5.9L Cummins (2003-2007.5) 3 11-14-2007 08:23 PM
SCT program question!!!!!! imported_07outlaw 2003-2007 6.0 Tuner Forum 0 12-23-2006 06:57 PM
FTP program???????? BigBlue The Parking Lot 5 04-11-2006 11:51 PM
