First Time pulling truck!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sjladd6_0L, this thread has received 22 replies and been viewed 2064 times.
post #1 of 23 (permalink) Old 07-27-2009, 02:12 PM Thread Starter
hay guys just wanted to know if im headed in the right direction here! I got an 04 crew cab dually 6.0 with and SCT programmer cfm large mouth intake kit and s+b intake, and i cut the stock muffler out and put in a straight pipe.
Now i am goin to the truck pulls this coming friday night, and did i mention that its goin to be my first time pulling? I was planning on starting out in 4hi and putting the truck in 2 gear with the programmer in the agressive tow mode!
Any helpful tips would help, Thanks!!!!
sjladd6_0L is offline
post #2 of 23 (permalink) Old 07-27-2009, 02:56 PM
strokin6L's Avatar
Do not use 4hi...use 4low. I've always used 4low and started in 2nd gear, then when it tached out i shifted to 3rd. I've heard alot of guys just leaving it in D(drive) and just let the tranny shift on it's own. But definitly use 4low. There's a local hometown pull in my area this sunday and am debating on pulling or not. Haven't decided, but it's been a couple years since i last pulled.
strokin6L is offline
The Following User Says Thank You to strokin6L For this addition to TDG:
sjladd6_0L (07-27-2009)
post #3 of 23 (permalink) Old 07-27-2009, 05:05 PM Thread Starter
ok so use 4low,
the pulls im goin to are at the franklin county field days in highgate vermont. I dont know how far that is from you but we always get a big crowd. This year there will be two sleds and the diesel trucks and the unlimited class doesnt start till late registration starts at 6pm.
post #4 of 23 (permalink) Old 07-27-2009, 05:07 PM Thread Starter
thats about 8 hours from you
post #5 of 23 (permalink) Old 07-27-2009, 05:11 PM Thread Starter
so i should use the agress tow tune or use the performance tune?
post #6 of 23 (permalink) Old 07-27-2009, 07:11 PM
strokin6L's Avatar
Yes, use 4low. And use your highest HP setting to get the best out of your truck.
post #7 of 23 (permalink) Old 07-27-2009, 07:30 PM
tire air pressure is another big thing to watch. keep the back tires relatively hard and drop the front ones some.
2003 6.0 6sp Black, black 6in stacks, scan gauge, gauges, Fass 150/180, ARP headstuds, RCD 200cc injectors SBC 3600 DD 12 cb, SCT X2, AFE stage 2 intake, zoodad mod, custom traction bars, a 2.6 66mm turbo in the making, and more fabricated parts in the near future. a 2.6 class 6.0 puller
Work truck: chevy 3500 454ci hightop fully enclosed reading utility bed
Gavin
03strokerGavin is offline
The Following User Says Thank You to 03strokerGavin For this addition to TDG:
sjladd6_0L (07-28-2009)
post #8 of 23 (permalink) Old 07-27-2009, 07:36 PM
strokin6L's Avatar
post #9 of 23 (permalink) Old 07-27-2009, 11:42 PM
scotty2280's Avatar
drop the fronts down to around 20psi, manually lock your front hubs, use your hottest tune, do a boosted launch, and as stated above 4lo-3rd or drive, not 4hi. give her hell!!!
04 6.0, studs,dj fuel +,isspro gauges,sct by eric,4in silverline w/o kitty,HID's, and other odds and ends
scotty2280 is offline
The Following User Says Thank You to scotty2280 For this addition to TDG:
post #10 of 23 (permalink) Old 07-28-2009, 12:34 AM
I Wanna Go Fast!
brentos's Avatar
OK put it in 4lo 2nd gear (since you have a dually you will need to start in a lower gear because of more bite) HOLD THE BRAKES and make about 15+ psi of boost then let off and the brakes and floor it. once you get going a little watch the tach and once it gets to about 4k rpm manually shift it into third and keep her pinned till you stop moving. Also use the performance tune
brentos is offline
The Following User Says Thank You to brentos For this addition to TDG:
466 pulling truck strokedout_07 Diesel Conversion 15 12-06-2010 03:49 AM
Build a pulling truck or pulling tractor? SOOTBANDIT The Polling Place 24 02-25-2009 04:54 PM
Pulling Truck Anyone??? bigdraft The Parking Lot 4 12-15-2007 11:16 PM
Truck pulling to the right need help! sesent General Ford Truck and Excursion 2 07-03-2007 11:09 PM
first time pulling, any pointers? PSDan000 Sled Pulling 22 09-19-2006 03:11 AM
