ditch the banks 6 gun? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bandersnatch, this thread has received 11 replies and been viewed 1231 times.
post #1 of 12 (permalink) Old 07-29-2009, 02:08 AM Thread Starter
I got it with the truck and wondering if its worth getting a sct instead? does the sct help the tranny at all? thanks brian
1999 F350 EXT cab long bed dually. Auto trans
k/n intake,Magnalfow 4" turbo back exhaust, pyro, boost and trans temp gauges.DP tuner,no start,stock,60hp tow,80 eco,120 race,140 arg.
2006 f250 4dr short bed. auto trans, Studs, Airdog2, boost,trans,pyro,fuel gauges, SCTx3,banks intake and exhaust ,coolant filter, egr welded up,ccv reroute and some 20" hd wheels.
Bandersnatch is offline
post #2 of 12 (permalink) Old 07-29-2009, 02:11 AM
********* and Mafia #90
Bcarriveau's Avatar
Yes, banks will eat your trans right up is you hot rod your truck
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
The Following User Says Thank You to Bcarriveau For this addition to TDG:
Bandersnatch (07-29-2009)
post #3 of 12 (permalink) Old 07-29-2009, 02:25 AM Thread Starter
is sct better on the tranny?
post #4 of 12 (permalink) Old 07-29-2009, 02:27 AM
I Wanna Go Fast!
brentos's Avatar
oh yea screw banks there software sucks. i used to run it and it doesnt even compare to sct. there are so many people that have switched to sct on here its not funny https://www.thedieselgarage.com/forum...switched+banks
brentos is offline
The Following User Says Thank You to brentos For this addition to TDG:
post #5 of 12 (permalink) Old 07-29-2009, 02:40 AM Thread Starter
you guys sold me . which one should i buy,x3 or live wire?
post #6 of 12 (permalink) Old 07-29-2009, 02:43 AM
I Wanna Go Fast!
brentos's Avatar
the x3 is great and cheaper as long as you like Analog (pod gauges) or the livewire has gauges built in. Personally i have owned both and would recomend going with the x3 both tune the same just gauges is the only difference
brentos is offline
post #7 of 12 (permalink) Old 07-29-2009, 02:43 AM
Bcarriveau's Avatar
x3.
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #8 of 12 (permalink) Old 07-29-2009, 03:05 AM
Pappy
MOPSD250's Avatar
X3 You can't go wrong with it!!! Then get you some custom tunes. Alot of reputable tuners out there.
2003 F250 Super Duty SC 8' Bed 12V CONVERSION DONE!!!!
24V P-pump Conversion Soon
MOPSD250 is offline
The Following User Says Thank You to MOPSD250 For this addition to TDG:
post #9 of 12 (permalink) Old 07-29-2009, 01:34 PM
Let it all Ride
Eazydeezy's Avatar
Go with the x3 unless you want a toaster sized aperatus sitting on your dash!
Dominic
Eazydeezy is offline
post #10 of 12 (permalink) Old 07-29-2009, 03:33 PM
Bcarriveau's Avatar
Da Rules..Here
Dear Tequila:
The TDG TOTQ
These 08's are tough!! - went in the ditch Hollywood 2008-2010 6.4L Power Stroke 26 03-01-2009 01:39 AM
Texas Ditch Surfing Snowaholic The Parking Lot 13 01-18-2008 01:53 AM
Another tranny, should I ditch my DP tuner? circlev 1994-2003 7.3L Chips & Tuners Forum 6 01-03-2008 08:53 PM
New Ditch Witch Trencher wideopen General Diesel 10 01-04-2007 09:13 PM
Should I ditch the kitty? 75867586 2003-2007 6.0L Power Stroke 33 08-28-2006 08:11 PM
