what tuners the best for mileage?!?! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DUMPIN99, this thread has received 9 replies and been viewed 1368 times.
post #1 of 10 (permalink) Old 08-05-2009, 09:31 PM Thread Starter
TURBO BOOST
DUMPIN99's Avatar
i just bought a 06 f-250 powerstroke what is the best tuner for mileage and one that will not blow the motor up in a week? gimmie some help guys!!
99 F-250 powerstroke. straight piped, 6" tip,k&n intake,6 position TS performace chip(stock, high idle, 50, 75, 100,140)
204,000 miles
:smoke
DUMPIN99 is offline
post #2 of 10 (permalink) Old 08-08-2009, 12:23 PM
dmilkman's Avatar
I have the Dr Performance triple play module...works great for me and a friend that has a 05 Excursion
No overfueling,great power and mileage gains.no changing the computer...I wanted to play it safe also.check them out.
Do asearch for them on google and some other websites sell them cheaper..I got mine from Jegs.com for $305 couple of years ago.You can call Dr performance direct and ask for a tech to ask any questions you have...good service.
http://www.drperformance.com/
http://www.drperformance.com/how.html
http://www.drperformance.com/test.html
http://www.drperformance.com/product...b=items&icd=20
dmilkman is offline
post #3 of 10 (permalink) Old 08-08-2009, 04:19 PM
********* and Mafia #90
Bcarriveau's Avatar
SCT. There is no tuner that can come close to the perfection of fine tuning to your needs and perfect shifts.. Anytime you get into a MODULES/Chips your just very cheaply fooling the computer and not getting accurate tuning as the pcm is just getting false data. Not to mention no trans tuning..So say short life to that. These motors are ~12K new and i for one would not run anything but a sct. So if you want to play SAFE doing it right is the only way.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
The Following User Says Thank You to Bcarriveau For this addition to TDG:
cash76 (08-10-2009)
post #4 of 10 (permalink) Old 08-09-2009, 08:11 AM
I get good MPGs with Inovatives Extream street or Agresive street tunes. But if you get on it, your MPGs will go right out the window but man it feels great.
heavyhaller is offline
post #5 of 10 (permalink) Old 08-10-2009, 02:44 AM
Dually Club #3
jdydiesel's Avatar
I have to say that I got my best mileage with my Banks PowerPDA set on SL. I would average 18mpg. Now that I run the SCT tunes the best I can get is about 15MPG. I have been told thought that Banks get the mileage from high cylinder pressures which the 6.0l doesn't like. If I was a conservative driver and never put my foot in it, then I would go with Banks for mileage (my dad is perfect for that type of tuner). But if your are like me and can't keep the skinny pedal off the floor then you have to go with the SCT, there is no better for tuning and performance, just not the best fuel mileage. When I check my mileage it was always on the lie-o-meter and I would set my cruise at 59 mph and run the same stretch of freeway so I know my numbers are at least consistent.
Jason
72 F-250 Gasser.FOR SALE
jdydiesel is offline
post #6 of 10 (permalink) Old 08-12-2009, 02:47 PM
The best mileage device is your right foot tuner... You can get really good and bad mileage from any tune, its all on how YOU drive the truck...
'03 F250 CCSB SRW, SCT, K&N, MBRP STRAIGHT PIPED, SNOW STG 3, LIFTED 6" ON 37'S, RCD's EGR DELETE, AP HD200, TP STG 1 FUEL SYSTEM, HYPERMAX STG 1 INJECTORS, ARP'S, ID TUNED, VARIOUS LITTLE GOODIES...
R33615 is offline
post #7 of 10 (permalink) Old 08-21-2009, 02:21 AM
PiRiPi's Avatar
Send a message via AIM to PiRiPi
55mph and under u would get great MPG , and city driving take off slow and dont blow black smoke to look cool that black smoke is like a gal of unburned diesel
6.0L2005 2wd crew cab,afe intake,5" exhaust,coolant filter,high idle mod,EGR delete,APR studs,Harley lights and Grill,6000k hids,fomoto drain valve,60gal rds tool tank,egt,pyro,trans isspro gauge 2" leveling front,moog ball joints, rancho 5000's, & TUNES BY
Innovative Diesel
Soon-Air dog 2, 155 rcd injectors, vgt-ss Stage I
PiRiPi is offline
post #8 of 10 (permalink) Old 08-22-2009, 12:32 AM
Haulin' Hay
NCfarmboy's Avatar
I got slightly better mileage with my Edge Platinum set on level 5, and being easy on the throttle -- but I'm running an SCT the 90hp Spartan tune now, and my truck loves it. Very good mileage, and plenty of power.
NCfarmboy is offline
post #9 of 10 (permalink) Old 08-24-2009, 01:28 AM
vcassens's Avatar
what kind of milage are you guys seeing out of you trucks?
2004 ford F350 6.0L 6 speed manual,SCT live wire,south bend double disk clutch,short throw shifter fx4. Costome exhaust 4 inch turbo back to 5" homade stacks, banjo bolt mod, shimed regulator,custom leveling kit (not blocks) and air lift air bags with onbord air suply TRADED FOR
2006 ford F 250 Amarillo 4" turbo back other than that stock for now
singles club #206
bomb squad #67
Ridin' Dirty Club #65
vcassens is offline
post #10 of 10 (permalink) Old 08-24-2009, 05:21 AM
Bcarriveau's Avatar
the way i drive... i see 14.5 most the time. if i baby it i can see 17s maybe a bit more but i cant baby it that much
Da Rules..Here
Dear Tequila:
The TDG TOTQ
Tuners joepa1 LMM Tuner Forum 1 04-26-2008 11:31 AM
Tuners helping Mileage? imported_smotley7601 5.9L Cummins (2003-2007.5) 5 10-22-2007 03:47 AM
tuners ?'s alldiesels LBZ & LLY Tuner Forum 6 12-24-2006 04:48 AM
chips tuners and fuel mileage just visiting 1994-2003 7.3L Chips & Tuners Forum 4 06-16-2006 07:13 AM
Tuners BROKER GM Performance Forum 3 05-04-2006 11:56 AM
