sct powerup msg timeout? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by asu20ram, this thread has received 20 replies and been viewed 3183 times.
post #1 of 21 (permalink) Old 08-11-2009, 11:29 PM Thread Starter
hey i just got a tune from rcd and loaded it onto my xcal. went to the truck to install it and plugged the module in, selected install tune, and it says turn key on. now it just sits there for a little bit then says powerup msg timeout. it says error reading dtc's and it cant read the strategy either. im in no way saying the tune from rcd has anything to do with, it just happened when i went to load this tune. anybody else ever have this problem, i've checked all fuses and the truck starts and runs fine. anybody? tia
asu20ram is offline
post #2 of 21 (permalink) Old 08-11-2009, 11:30 PM
********* and Mafia #90
Bcarriveau's Avatar
x2,x3 or sf3?
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 21 (permalink) Old 08-11-2009, 11:38 PM Thread Starter
its an x2
asu20ram is offline
post #4 of 21 (permalink) Old 08-12-2009, 12:19 AM
Bcarriveau's Avatar
i would contact sct..
http://www.sctflash.com/tech.php you can try the online chat but its one of the worst setups out there and cant ever get threw to anyone. i waited 4 hours one day : , wait an hour then it says they are offline. back and forth. id just call when you are by your PC and have time.
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #5 of 21 (permalink) Old 08-12-2009, 12:20 AM
whanner's Avatar
mine did something like this....I opened it up and there was an orange wire that had broken off at the circuit board. re-soldered it and it works like a charm now. i also took a hot glue gun and covered all the wires so they would have a strain relief. if your going to do this, once you get it open just wiggle each wire and make sure they are still connected to the circuit board. you also may want to do a continuity test for each pin in the harness back to the circuit board and make sure there is not a break in the cable. hope this helps.
06' F350
I'm not a Diesel Mechanic or Expert. All posts are just guesstimations.
4" Turbo Back Exhaust, 2" lift in front,1" Lift In the Rear, EGT Gauge, ARP Studs.
whanner is offline
The Following 2 Users Say Thank You to whanner For this addition to TDG:
asu20ram (08-12-2009), Bcarriveau (08-12-2009)
post #6 of 21 (permalink) Old 08-12-2009, 12:31 AM Thread Starter
i popped mine open and theres an orange w/black stripe and brown one broke loose from the circuit board... now i gotta find me a soldering gun and hope i get them back in the right spots haha
asu20ram is offline
post #7 of 21 (permalink) Old 08-12-2009, 12:33 AM
Bcarriveau's Avatar
dang look at that. good work guys Maybe take a picture for reference for other members if you have time
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #8 of 21 (permalink) Old 08-12-2009, 12:43 AM Thread Starter
heres a picture of the little boogers. now i just gotta get'em soldered back on there.
Name:	2009-08-11 19.37.14.jpg
asu20ram is offline
The Following User Says Thank You to asu20ram For this addition to TDG:
post #9 of 21 (permalink) Old 08-12-2009, 12:57 AM
whanner's Avatar
I also put some padding under my circuit board before I put it back together....now it doesn't rattle. every time we use these tuners the wires are moving back N forth till the finally break off... they really need a better strain relief on them.
06' F350
whanner is offline
post #10 of 21 (permalink) Old 08-12-2009, 01:01 AM Thread Starter
i agree. i bought mine used and where the cable comes out of the tuner has always been loose and usually comes out, this was even after i had to send it back to sct to unlock it almost two years ago. definately not a good design on sct's part.
asu20ram is offline
