Edge Juice Platinum w/Atitude - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jpmaes0622, this thread has received 7 replies and been viewed 1132 times.
post #1 of 8 (permalink) Old 08-23-2009, 06:33 PM Thread Starter
I currently have an Edge Programmer, and yes, yes I will be changing it out to an SCT.
But for the time being, is there any way to protect the tranny if I am gonna push up the level on the programmer, before.....?
Any info for the Edge would be greatly appreciated while I await SCT and Custom Tunes.
jpmaes0622 is offline
post #2 of 8 (permalink) Old 08-23-2009, 06:42 PM
********* and Mafia #90
Bcarriveau's Avatar
i would say your right foot is the only protection for your transmission that you have. that is with anything.
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 8 (permalink) Old 08-25-2009, 12:45 AM
Haulin' Hay
NCfarmboy's Avatar
Actually, the Platinum (despite what most folks will say) has some level of transmission controls, and isn't nearly as tough on your tranny as the older Edge programmers...
I put 80k hard miles on my truck with it, although I hardly ever went over level 3. Just set your defuel setting to 0% -- and drive sensibly.
NCfarmboy is offline
The Following User Says Thank You to NCfarmboy For this addition to TDG:
jpmaes0622 (08-25-2009)
post #4 of 8 (permalink) Old 08-26-2009, 01:44 PM
illadvised and dangerous
Lubbockguy1979's Avatar
Send a message via Yahoo to Lubbockguy1979
The reason the newer edge systems are better for the tranny if you want to call it that is less power. They offer a hot unlock with more power but you sign a waiver and pay more. Also I have read the hot unlock is still less power than original tuners though
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
isspro egt/boost/trans/fuel
as well as pretty much
everything else
Lubbockguy1979 is offline
post #5 of 8 (permalink) Old 08-27-2009, 02:17 AM
SLAPS President
teamroper60's Avatar
Images: 9
That is only partly true.
The original had the following settings:
Level 0: Stock
Level 1: 40 hp & 80 ft-lbs of torque
Level 2: 60 hp & 100 ft-lbs of torque
Level 3: 80 hp & 160 ft-lbs of torque
Level 4: 100 hp & 250 ft-lbs of torque
Level 5: 115 hp & 290 ft-lbs of torque
The Platinum has these:
Level 0: Stock
Level 1: 25 hp & 50 ft-lbs of torque
Level 2: 40 hp & 80 ft-lbs of torque
Level 3: 60 hp & 120 ft-lbs of torque
Level 4: 80 hp & 160 ft-lbs of torque
Level 5: 100 hp & 200 ft-lbs of torque
HOT: 115 hp & 240 ft-lbs of torque
So in truth, the Platinum with the hot unlock gives you the same hp power levels plus another, lower power level the original did not have.
The actual difference is torque (which is the real transmission killer). As you can see from the numbers posted, the Platinum actually has 20 ft-lbs more torque in the 60hp setting than the original had but is 50 ft-lbs less in each of the 100hp and 115hp settings...
jpmaes0622,
Your best bet is to stay out of anything higher than level 3 or 4 and set your defuel to 0. If you go up to level 5 or the hot unlock, the trans will not like you and eventually, you will not like it either....
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #6 of 8 (permalink) Old 08-27-2009, 08:06 PM
caveman666's Avatar
I ran mine hard on 5 and sometimes 6. Think I had 60,000 k when I switched. never had a problem. I now have 120000+ and still no problem. The Platinum isn't bad. It was the original juice that was hard on tranny's.
2005 Black F-350. Suncoast Creations Ram air Hood, Looney Tuned SCT, Edge Insight,EGR Delete,ARP'S, ARE tonneau cover, Recon smoked cab,mirror and 3rd brake lights. MBRP turbo back duals, Airaid intake.ICON 4.5" Lift,Bushwacker Flares, 20x10 Eagle alloys wrapped with 35x12.50r20 Nitto Mud grappler(too Loud!).Amsoil bypass filter.Pioneer F90BT for media.
STACKS ARE GAY!
caveman666 is offline
post #7 of 8 (permalink) Old 09-01-2009, 10:13 PM
I run my platinum edge on "hot" whenever I feel like it, but usually daily drive level 3... I've probably put 30k miles since got the edge, and have had the hot unlock for probably 10k miles and no problems at all...
careatr is offline
post #8 of 8 (permalink) Old 09-18-2009, 05:12 AM
awhotrods's Avatar
I have 160K miles on my 03 with Edge Juice with Attitude, has been on since 30K miles and ran it on level 4 or 5 the whole time with no issues!
03 F350 4x4 6.0 PSD
SCT X3 with Eric's Xtreme Street Tune
RCD EGR DELETE
RCD 155's
4" TURBO BACK STRAIGHT PIPED
DIESEL SITE COOLANT FILTER
ACCUFAB 05 ELBOW
STATOR REMOVED (NO ISSUES)
ZOODAD MOD
ISSPRO TRIPLE GAUGES
05 HARLEY FRONT END
08 REAR CONVERSION
awhotrods is offline
Edge Juice Platinum, 05 F-250 ehowarulz 2003-2007 6.0L Power Stroke 2 06-08-2009 02:06 PM
Edge A2 with Juice Platinum 6.0 shelby_hauler Whats Been Sold 5 02-26-2007 02:46 AM
Edge Juice Platinum for 6.0L Phoneguy982 Whats Been Sold 1 07-22-2006 03:09 AM
Edge Juice Platinum Or Sct redzilla 2003-2007 6.0 Tuner Forum 23 05-07-2006 05:07 AM
Edge Juice Platinum redzilla General Ford Truck and Excursion 2 04-27-2006 01:55 AM
