Went to the dealer - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lubbockguy1979, this thread has received 13 replies and been viewed 1303 times.
post #1 of 14 (permalink) Old 08-27-2009, 07:21 PM Thread Starter
illadvised and dangerous
Lubbockguy1979's Avatar
Send a message via Yahoo to Lubbockguy1979
Went to the dealer
So I recently stuffed 35" tires on my stock truck and since I'm going to be logging a few thousand miles next month I decided I would have ford calibrate the spedo so it would be accurate. I called around and one dealer that had done warranty work in the past for me said they could do it for $80 bucks and if they couldn't do it there would be no charge. They were unable to get to it today so I called the other dealer here that recently fixed my truck out of warranty. They were able to get to it right then and I took it in. I told the service writter the tire size rear diff gears etc to make 100% they were on the same page to be able to set it accurate. He assured me they could get it right. I waited a hour and a half and got the truck back only to have the service tech tell me that the best he could do was get it within 5mph off. This dealer wanted $94.04 for calibrating the speedo that was 6mph off to 4mph. I called and talked to the shop manager and after griping for 20mins he finally decided to just refund my money. Is it impossible for ford to calibrate the speedo for 35" tires? I knew I couldn't do 37 or larger but was under the impression that 35"s were not a problem. On a side note I did return the truck to stock from my sct and I am out of warranty but I left my tuner in the seat when I got the truck back it drove 100% better almost as if the tech had installed one of the tunes off my programmer. I haven't looked at the strategy yet but do you think he reinstalled the tunes on the truck after the flash he did? Or is it possible he reflashed it and I got a better flash? The truck actually would put out some smoke after I got it back and had more get up as well.
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
isspro egt/boost/trans/fuel
as well as pretty much
everything else
Lubbockguy1979 is offline
post #2 of 14 (permalink) Old 08-27-2009, 07:28 PM
SmokeCloud's Avatar
It is a possibility, have the dealer check to see if they flashed, or take it to a tuner.
Real Trucks Burn Diesel!
SmokeCloud is offline
post #3 of 14 (permalink) Old 08-27-2009, 11:06 PM
scotty2280's Avatar
read your tuner and see what tune is in it
04 6.0, studs,dj fuel +,isspro gauges,sct by eric,4in silverline w/o kitty,HID's, and other odds and ends
scotty2280 is offline
post #4 of 14 (permalink) Old 08-28-2009, 01:50 AM
StrokerDude's Avatar
They can only calibrate the speedometer up to the largest tire that they offer stock which is somewhere around a 33.
Alex C.
StrokerDude is offline
post #5 of 14 (permalink) Old 08-28-2009, 02:26 AM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
Dealerships can do up to 35's...I had mine done long ago.......the guys you are dealing with are idiots...
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #6 of 14 (permalink) Old 08-28-2009, 03:15 AM Thread Starter
Thanks tank that is what I was leaning twards. As far as the tuner goes the xcal2 I have will not tell you what tune is on the truck. It will only allow you to return to stock or install one of the three tunes on the tuner
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
everything else
post #7 of 14 (permalink) Old 08-28-2009, 03:31 AM
SLAPS President
teamroper60's Avatar
Images: 9
The Xcal2 will read your stock strategy though and that is what folks are telling you to check...
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #8 of 14 (permalink) Old 08-28-2009, 01:47 PM Thread Starter
Sytayegy is the same I'm guessing the tech loaded up the ase program on the tuner because I loaded up hybrid and it was about the same as was the stock tune. Just find it weird that the ford tech would load one of my tunes to go test drive my truck..... Kinda pisses me off that he would have done that
2006 f250 4x4
crewcab lariat
auto elec tcase
soon to have
everything else
post #9 of 14 (permalink) Old 08-28-2009, 03:00 PM
ebusa's Avatar
This is correct!
-Evan
2005 F350 Crew Cab LB FX4 Lariat
Loaded-Leather, Sunroof, Chrome Mirrors,Tow hooks
5'' Tuff Country Lift
Toyo 35'' MT's on Race Line Renegade 20's
ARP Studs, EGR Cooler Delete, Coolant Filter
AFE Magnum Force Stage II CAI
MBRP 4'' Exhaust Turbo back, No Cat
SCT X3 Tunes -Strat: VXCF9
Powemax Turbo
PHP FICM tuner
ebusa is offline
post #10 of 14 (permalink) Old 08-28-2009, 03:23 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
IDS will not calibrate tires anymore up to 35". ... I can do it w/ auto enginuity but not with IDS..
2003 F250 "Pulling Truck"
hhrecovery is offline
Dealer ToyCollector 2003-2007 6.0L Power Stroke 0 06-06-2007 11:06 PM
How does the dealer know gobigorgohome 2003-2007 6.0 Tuner Forum 9 11-02-2006 01:31 AM
dealer says.... kiddsplash 2003-2007 6.0L Power Stroke 2 11-01-2006 09:27 PM
SCT and Dealer? imported_fast_and_furious 2003-2007 6.0L Power Stroke 14 03-14-2006 07:13 PM
can the dealer tell? imported_powerstrokebronco 2003-2007 6.0L Power Stroke 34 03-06-2006 06:27 PM
