Trans filter and fluid insight - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by barry1me, this thread has received 7 replies and been viewed 764 times.
post #1 of 8 (permalink) Old 09-16-2009, 05:01 AM Thread Starter
Which fluid do I need, how much....I will most likely be dropping the pan and replacing both filters.
Can you get the filters at international?
Any special procedures needed to do the change?
06 F250 6.0L ID tuning. RCD EGR delete 03 turbo
barry1me is offline
post #2 of 8 (permalink) Old 09-16-2009, 05:10 AM
lilpooh's Avatar
sp trans fluid from dealer.I think it's 8qts to refill the pan
i'm not sure about international
when you pull out the filter in the pan make sure the rubber o-ring seal comes out with it,and I think the trans pan gasket is reusable
2004 F350 CC DRW King Ranch
lilpooh is offline
post #3 of 8 (permalink) Old 09-16-2009, 10:52 PM
SLAPS President
teamroper60's Avatar
Images: 9
I don't think you can get the trans filter from IH. You can get it from dieselfiltersonline.com though at a better price than the dealer..
#43
Dually club member #76
SLAPS President and Webmaster
teamroper60 is offline
post #4 of 8 (permalink) Old 09-17-2009, 12:59 AM
Pappy
MOPSD250's Avatar
If you are going to do that get the tranny filter and pan for a 08!
2003 F250 Super Duty SC 8' Bed 12V CONVERSION DONE!!!!
24V P-pump Conversion Soon
MOPSD250 is offline
post #5 of 8 (permalink) Old 09-19-2009, 02:48 AM
Haulin' Hay
NCfarmboy's Avatar
Go buy your Mercon SP from O'rilies Auto Parts if there's one near you -- it's WAY cheaper there than the dealer. $3 something per qt -- Part # is MERCON SP
NCfarmboy is offline
post #6 of 8 (permalink) Old 09-19-2009, 03:10 AM
harleystroker's Avatar
Send a message via Yahoo to harleystroker
I need to change my fluids also but I'm worried that if I change it my tranny will kill over. the last time the tranny was serviced was at 40k and I now have 152k. Will I experience any issues if I change my fluid?
04 Harley F250 c/c s/b: 06 headlights, 3'' rough county lift, Eagle 20's, 35'' tarragrapplers, 4'' turbo back magnaflow with cat/muffler delete, 6000k HID's, Recon line of fire/ mirror lights/3rd brake/&Tales,Studs/gaskets,Tuned SCT X3,STL strobe kit, Icon shocks,Dfuser Egr/ Egr cooler delete, 03 turbo
http://i135.photobucket.com/albums/q...04/sq_com4.gif
harleystroker is offline
post #7 of 8 (permalink) Old 09-20-2009, 03:50 AM
Haulin' Hay
NCfarmboy's Avatar
You'll only experience problems if you don't change it! Trust me, your tranny will thank you.
post #8 of 8 (permalink) Old 09-20-2009, 04:07 AM
10-4 sounds good to me too bad I can't pick the filters up tomorrow looks like a task for next weekend. Maybe Ill get the 08 pan and filter
Trans fluid cummins kid General Dodge Discussion 16 05-06-2009 11:03 PM
Trans fluid out of top? Sean 007 Duramax 2001-2004 (LB7) 1 02-14-2009 06:16 PM
Checking Trans Fluid rsjohnsn 2003-2007 6.0L Power Stroke 3 03-16-2008 10:39 PM
What trans fluid? 19stroker96 1994-2003 7.3L Power Stroke 5 06-20-2007 01:33 PM
Synchromax Trans Fluid Callitbiznatch 2003-2007 6.0 Tuner Forum 2 02-23-2007 01:39 AM
